DR-DV5000 with GY-DV500 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old September 28th, 2004, 10:03 AM   #1
Does anyone have experience using DR-DV5000 with GY-DV500? Because some functions aren't working, maybe make sense to wait for FS-4?
Alex
Alex
Alex Shostak is offline   Reply With Quote
Old September 28th, 2004, 10:57 AM   #2
Focus Enhancements
Hi Alex,
What is not working? Maybe I can help. Also, have you contacted Focus tech support at support@focusinfo.com or at 408-370-9963?
Regards,
Matt McEwen
Matt McEwen is offline   Reply With Quote
Old September 28th, 2004, 11:57 AM   #3
This is my conversation with focusinfo customer support:
Questions:
I'd like to buy DR-DV5000 for my GY-DV500 camcorder, but I heard that there are a lot of limitation when it used with GY-DV500.
Q1. What functions are really work and what don't.
Q2. Have you recommend to by DR-DV5000 for use with GY-DV500?
Answer:
Dear Sir ,
The DRDV5000 was developed in conjunction with the JVC GYDV 5001/5001 .
All the features are utelized wuhen you would have that camera.
With any other camera ( no matter what brand ) you won't have that.
The major difference is the tapeless operation when you have the 5000 camera.
You are still able to slave the DRDV5000 to the GY-DV500.
Questions:
Thank you for prompt response. But unfortunately, I did not get answer I expect.
I understand that Not all function will work. Tapeless function is not an issue for me, because the main reason I want DR is for redundancy. But what happen if tape comes to en and or stuck inside the mechanism. Should DR-DV500 continue to operate or what happen. Sorry, but this kind of questions I'm interested in.
Answer:
If it gets stuck or jamms or the tape runs out , the DR DV 5000 will stop recording.
My comments:
Basically, I'd like to know specifically, what functions will not work with GY-DV500. For instance, I already know that I will not have display information in the GY-DV500 viewfinder, etc.
Alex
Old September 29th, 2004, 10:05 AM   #4
And one more question.
Will DR-DV500 record from GY-DV500 if camcorder in the standby mode and no tape (or tape in, but Rec button wasn't pushed)?
Thanks.
Alex
Old September 30th, 2004, 02:27 PM   #5
Focus Enhancements
Hi Alex,
Here is the main differences between DR-DV5000 operation on a JVC GY-DV5000/-5001 and a GY-DV500/-550/-700.
* Using Syncro Slave, it is possible to trigger record and record pause on DR-DV5000 from the GY-DV5000 with or without a tape present. On the DV500, a tape must be present to trigger record on DR-DV.
* Using the Split Slave Mode, it is possible to trigger rec/rec-pause on DR-DV separate to the camcorder's tape transport from the DV5000's front and side VTR button.
* System status of the DR-DV is displayed in the DV5000's EVF. This feature does not exist on DV500.
* Using the 52-pin connector, DR-DV mounts to the DV5000 without a FireWire cable. The DV500 requires a FireWire cable.
* The Dump to Disk and Dump To Tape features only operate on DR-DV with a DV5000. This allows you to automatically record the content of a tape to disk or vice versa.
* Series Record - where at X number of minutes before a tape ends, DR-DV will begin recording - is only available with a DV5000. If a tape ends while recording with a DV5000, DR-DV will continue to record while the tape is changed. On the DV500, DR-DV will stop.
* Power Management - If power is shut off on the DV5000 and DR-DV is not yet ready to shut down, the DV5000 will wait until DR-DV has shut down before powering down. This prevents corrupt files.
Hope that helps,
Matt McEwen
Old September 30th, 2004, 02:31 PM   #6
Focus Enhancements
Forgot to answer this one...as long as the camcorder is on (tape or no tape), it is possible to record to DR-DV5000. The FireWire (DV) port on the camcorder always outputs video. You will have to control DR-DV5000 from its front panel however.
Matt
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
