Long shots broken-up into small files when captured. at DVinfo.net
Old April 26th, 2004, 02:08 PM   #1
Long shots get broken-up into small files when captured.
Sometimes I film interviews, special events and other subjects which require continuous shooting; 5 minutes, 10 minutes or even longer (of continuous recording). Here is the problem I am running into:
When capturing with the HDcapture utility supplied with the camera 99% of the time the shot will lose synchronization and will be chopped up into many files. This presents some problems when producing final material. The files can be joint together in KDDI but then when played back there are jerks and visible discontinuities in the video, because of thoes few frames lost..
I have used many different top quality tapes with same results. The tapes were rewound before recording, recorder with dummy signal before recording, recorded on brand new blanks, etc... same issue.
When capturing with HDVCR capture utility the file seems continuous but KDDI gets confused when editing at the points that apparently have lost synchronization (they give me some weired packet errors). Video jerks are still noticable.
If anyone has any suggestions how to solve this problem, it would be great to read about it.
Cheers.
Christopher.
Christopher Winnicki is offline   Reply With Quote
Old April 26th, 2004, 05:11 PM   #2
This the first reply I got from JVC
From - Mon Apr 26 18:19:53 2004
X-UIDL: 1082996314.26622.pg-mail.playground.net
X-Mozilla-Status: 0003
X-Mozilla-Status2: 00000000
Return-Path: <DKersey@jvc.com>
Delivered-To: winnicki@playground.net
Received: (qmail 26617 invoked from network); 26 Apr 2004 16:18:33 -0000
Received: from unknown (HELO smtp.jvc.com) (207.10.33.121)
by 0 with SMTP; 26 Apr 2004 16:18:33 -0000
Content-Class: urn:content-classes:message
MIME-Version: 1.0
Content-Type: multipart/related;
type="multipart/alternative";
boundary="----_=_NextPart_001_01C42BAA.1D38F244"
X-MimeOLE: Produced By Microsoft Exchange V6.0.6375.0
Subject: HD Capture
Date: Mon, 26 Apr 2004 12:18:30 -0400
Message-ID: <7E9C549BBAB0C24F8792CD39B218717703CCEA5F@jacwynex01.jac.jvc.com>
X-MS-Has-Attach: yes
X-MS-TNEF-Correlator:
Thread-Topic: HD Capture
Thread-Index: AcQrqh7ww/afvER2Siu/XkROM/sglg==
To: <winnicki@playground.net>
This is a multi-part message in MIME format.
------_=_NextPart_001_01C42BAA.1D38F244
Content-Type: multipart/alternative;
boundary="----_=_NextPart_002_01C42BAA.1D38F244"
------_=_NextPart_002_01C42BAA.1D38F244
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Thank you for your inquiry. There are 2 possibilities for the file
segmenting. First, make sure your head are clean and that your firewire
cable integrity is not compromised. Second, ensure that your file
system is Not Fat32 as it has limits to the size of a single file.
=20
Dwayne Kersey
Professional Products Support Specialist
JVC Americas Corporation
1700 Valley Road
Wayne, NJ 07470
And here is my reply to Dwayne Kersey of JVC
The camera is brand new and there is not even 10 hours of head time on it so I don't see how the "dirty" heads could cause this? In addition I did not see any guidelines for cleaning the heads in the manual or the type/grade of tapes that should be used (I use the best grades anyhow)
ieee1394 cable is not the issue. As I have mentioned in my initial inquiry when recording directly to the hard drive (through the firewire) the file never loses synchronization.
The file system is not Fat32 (I know about the 2GByte limit), so this can't be an issue.
Please advise further.
-Christopher.
Old April 26th, 2004, 08:55 PM   #3
Re: This the first reply I got from JVC
<<<-- Originally posted by Christopher Winnicki : First, make sure your head are clean. -->>>
Take JVC's suggestion.
Try cleaning your tape heads for about 10 seconds.
Maury
Maury McEvoy is offline   Reply With Quote
Old April 27th, 2004, 10:13 AM   #4
CineForm (Aspect HD)
Certainly try the head cleaning tape first and if that doesn't work I would try one of your tapes with a different HD10U camera. I'll bet you will find you are able to capture without problem.
Phil Wright is offline   Reply With Quote
Old April 29th, 2004, 06:22 PM   #5
The troubles continue, more when warm
I don't have another HD10U (or HD1U) to put the tape into, for sure this is the first, best, most logical and easiest troubleshooting method to determine what is the problem.
It seems that when the camera is first turned on (from cold; meaning: the cameras has been off over night) and the capture is started then it captures the longest segments. I was able to capture 1.7GB continues and then the whole thing fell apart and started segmenting.
I tried to capture again from the beginning (once the camera was warmed-up and tape rewound) and the segmentation started almost immediately, 200MB, 110MB, 50MB, 17MB....etc.
Here is the reply to JVC:
I did clean the head with the tape supplied with the camera (JVC M-DV12CL) following the instructions supplied with the tape. There was no improvement to the capture of long takes.
On the first iteration a clip of 43min (take) was broke up into 37 files, here is the breakdown:
1 file at 2.4GB
1 file at 700MB
4 files at 200MB
5 files at 100MB and the rest of the files where all below 100MB. (I think you get the idea)
The second time I captured the same clip (after 10 more seconds of cleaning) the result was even worst. There was no file over 300MB and a total of 43 files. During the capture every time the lcd turned blue another file as written.
It is impossible to work with this kind of video segments because even after "gluing them up" in the KDDI studio there is a very noticeable jerk at the segment junction point. When working with interviews or speaches this makes the material essentially un-salable
Christopher Winnikci.
From - Tue Apr 27 20:31:53 2004
X-Mozilla-Status: 0001
X-Mozilla-Status2: 00800000
Message-ID: <408EFB78.6050404@playground.net>
Date: Tue, 27 Apr 2004 20:31:52 -0400
From: Christopher Winnicki <winnicki@playground.net>
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7b) Gecko/20040316
X-Accept-Language: en-us, en
MIME-Version: 1.0
To: "Kersey, Dwayne" <DKersey@jvc.com>
Subject: Re: HD Capture
References: <7E9C549BBAB0C24F8792CD39B218717703CCEA5F@jacwynex01.jac.jvc.com>
In-Reply-To: <7E9C549BBAB0C24F8792CD39B218717703CCEA5F@jacwynex01.jac.jvc.com>
boundary="------------050703040405010201060500"
Old April 30th, 2004, 12:48 AM   #6
Sounds like a camera problem to me.
We had a customer with a similar problem though not as bad as you are experiencing.
If you have a tape that you want checked on a different camera you can send it to me care of CineForm (address on website) and I can run it through one of our cameras.
Old April 30th, 2004, 01:59 AM   #7
I noticed it did the same thing to me a couple of times, then I free'd up lots of disk space on my av drive, defragged it and 'wow' problem solved, I think there is a problem with capture to average consumer 7200rpm HDD's once data is being put onto inner sections of the platters it seems like its not quick enough to capture and files get split up into progressively smaller chunks, might help it did for me.
Regards,
Sam Sharpe
Sam Sharpe is offline   Reply With Quote
Old April 30th, 2004, 08:42 AM   #8
The problem continues
<<<-- Originally posted by Phil Wright : Sounds like a camera problem to me.
If you have a tape that you want checked on a different camera you can send it to me care of CineForm (address on website) and I can run it through one of our cameras. -->>>
Thanks Phil, I think I will take you up on that offer. If I send with return postage paid will you send the tape back?
I just took a look on the www.cineform.com site and the address was not exactly "jumping out" at me.
The hard drives can not be an issue. I have already said that when I am capturing directly to the hard drive the fragmentation never happens. Speed of the drives can not be an issue either (I don't think). I have a two 160GB drives with 8MB buffers setup in RAID 0 configuration (lots of free space) (defragged or not, the same thing happens)
I should also mention that when the fragmentation happens it always coincides with the “blue” screen on the lcd display on the camera.
Old April 30th, 2004, 09:14 AM   #9
Chris,
Will certainly ship the tape back to you after I've run it through a camera here.
Here's the address:
CineForm
Attn: Phil Wright
5315 Avenida Encinas
Suite 230
Carlsbad, CA 92008
Old April 30th, 2004, 11:35 AM   #10
The tape is in the mail
Phil,
I just mailed the tape to the address you have listed.
Please let me know if/when you (if ever) receive it.
Canadian mail system is "best effort" at best, like everything else in this Marxist wonderland.
Old April 30th, 2004, 12:11 PM   #11
Is this an error correction problem on the JVC?
Looks to me like it is dumping the whole data stream with certain types of errors on the media read.
-Les
Les Dit is offline   Reply With Quote
Old April 30th, 2004, 03:50 PM   #12
I'll keep an eye out for it.
Phil
Old June 29th, 2004, 08:44 PM   #13
I think it's the capture s/w that came with the camera
Hi Phillip.
I have tested out my camera (HD10U) with different capture software and the breaking up of continuous clips does not happen like it happens with the capture software that came with the camera.
In particular I have tested it on a computer that had adobe premiere installed on it along with the MainConcept HD plug in, the capture process worked flawlessly not a single frame was dropped.
Another time I tried to capture the whole tape with DVHStool software and there were no brakes in video.
I don't know to what other concussion I can come other than blaming the capture software that shipped with the camera?
-Chris.
Old June 29th, 2004, 11:14 PM   #14
While the included software is prone to detecting scene breaks that aren't there and other issues I have never seen it do what you described.
But as long as you are able to capture now that's all that really matters. :)
Phil
Old June 30th, 2004, 01:03 PM   #15
My observation...
..with the included capture utility, is no discontinous interruptions of the stream. It properly creates a new file at each scene break.
P4 2.8ghz HT
512mb ram
5400 rpm HDD
Tom Roper is offline   Reply
