Curious about PentiumM chips... at DVinfo.net
Old April 2nd, 2005, 12:42 AM   #1
This might not be the right forum for this question...
But... what are the advantages of using a pentiumM chip???
Of course good batt time... but anything else????
At all?
I am trying to create a mobile editing station and thinking should I get a pentiumM laptop.... or a straight out... p4 3.6mhz?
Any input would be greatly appreciated and thanks!
Brent Marks is offline   Reply With Quote
Old April 2nd, 2005, 09:14 AM   #2
Speaking for Aspect HD, the fastest Pentium M's on a laptop work well. Your biggest challenge on a laptop will be the drive speed, so consider using an external 7200 rpm Firewire/USB drive. Also more memory will get you more sustained RT performance, so spring for as much memory as your budget will allow - 1GB min, preferably 2GB. With 1080i material, you'll get atl east dual-stream RT performance with an occassional third stream depending on what you're doing.
I personally have a 3.2GHz (desktop CPU) laptop, and I'd rather have a 2.13GHz Pentium M because the form factor is more manageable with better battery life when I'm not doing video work.
David Taylor is offline   Reply
