Change 1394 switch? (JVC HD 100) at DVinfo.net
Old April 26th, 2010, 03:50 PM   #1
So I just received a used HD 100 today, I went out shot some footage, returned to capture and to my dismay when I went to capture the camera continually blinks "Change 1394 switch". I shot in HDV 720 24p and I am capturing in Vegas pro 9. My PC recognizes the camera but Vegas does not and will not capture. Is this an indication of a blown out firewire port or is their something I'm doing wrong? This is my first tape camcorder so I'm a novice at the whole capturing side of things.
Dan Frantz is offline   Reply With Quote
Old April 26th, 2010, 07:03 PM   #2
if you shot in hi def mode, make sure your firewire switch is on the hdv mode, and visa versa if you shot it in SD...its near the back of the camera, right side.
John Abbey is offline   Reply With Quote
Old April 26th, 2010, 07:22 PM   #3
power down the camera and on the back is a switch marked DV /HDV.
bet your switch is in DV mode.
did I mention power down the camera
John Sirb
Lake Breeze Video
John Sirb is offline   Reply With Quote
Old April 27th, 2010, 06:52 PM   #4
Wow, well that did the trick. Not sure how I overlooked that. Guess I need to go print out a copy of the manual and read up... Thanks guys!
Old April 28th, 2010, 07:39 PM   #5
Yup, As lame as the manual is....
LOL, !
The manual is extraordinarily lame for this camera. But, as they say, (just read the Fckn thing)
Anyway ...cheers on the camera. Check out the "sticky" posts at the top of this forum.
You will find amazingly valuable info that will save you an enormous amount of time towards great images thanks to some extremely generous contributors...(Tim and Paulo are not to be missed)!
Enjoy and make some great images!
Jay Webster
WPI/NY
Jay Webster is offline   Reply With Quote
Old May 3rd, 2010, 03:34 AM   #6
Since you're a new owner, and if no one has told you yet, make sure you have your computer and cam powered down when connecting the firewire, esp if you use Mac. I use one of the little $8 firewire de-energizers. Blow that firewire board and you're sunk.
Old May 3rd, 2010, 09:55 AM   #7
Where do you buy those?
Corey Williams is offline   Reply With Quote
Old May 3rd, 2010, 07:38 PM   #8
Caution with the firewire connection and HDV switch cannot be emphasized enough! Blow it and you are in for a pricey fix not to mention the time out without the camera.
I got what was called a port isolator, (short connector that kills the bus power transfer in the firewire), I believe from firewire depot.com, not sure. But, there are posts on the forum about this exact thing. Try doing a search for firewire or port isolator...etc.
Also see this: FireWire Port Isolator - 6pin - 6 inch
Jay Webster
WPI/NY
Old May 3rd, 2010, 09:45 PM   #9
Thanks for the heads up I've been sure to power everything down before connecting but it seems like a port isolator would be a good investment. My PC has a 4 pin connection and I'm using a 4 to 6 pin fire-wire cable. I did a quick search but didn't find any results for a 4 pin fire-wire isolator. Would it be practical to use a 6 pin isolator to plug the 4 to 6 pine firewire into and then plug the isolator into the camera? Would that still knock out the bus power?
Old May 4th, 2010, 07:13 PM   #10
Dan,
Yeah, I have a similar setup: Firewire 6pin from camera to a 4 pin laptop. Using On Location for file capture.
The adapter does exist. the main point is that even with the adapter I never power anything up until all connections are made and secured.
Again, I always connect before powering up either the camera or the computer. In a way the adapter is just one more safety reminder. I also have a Post It note on the laptop as a reminder just in case I or someone gets boneheaded.
Jay Webster
WPI/NY
