HD200 - Wedding Stills at DVinfo.net
Old July 11th, 2007, 01:18 AM   #1
Hi ,
I rented a HD200 for a personal test - here are some stills of the wedding.
http://www.media-in-work.de/fuer_vvf...200/hd200.html
It was
HD200 + STd. Lens (TH16x...) + Fujinon WA converter (0.82).
720 50P captured with Sony Vegas.
No postpro yet, straight out of the cam.
Settings: Blackstretch (+3 I think), Knee ~85%, Detail -5 , no matrix settings.
ULI
Last edited by Uli Mors; July 11th, 2007 at 01:19 AM. Reason: ..forgot the link...
Uli Mors is offline   Reply With Quote
Old July 11th, 2007, 05:50 AM   #2
Black Stretch at +3 tends to make the picture a little washy and low contrast for my tastes. It also adds a far amount of noise to the picture.
You may need it for a certain purpose, but even in low light, I think it is best to stick with standard gain.
Mike Marriage is offline   Reply With Quote
Old July 11th, 2007, 06:53 AM   #3
Yes some of those images are alittle to gainy for my taste i must say
Tyson Perkins is offline   Reply With Quote
Old July 11th, 2007, 06:17 PM   #4
I liked the shots Uli.
The black stretch is a must at the reception and in run and gun low light situations. I can see it made a big difference at yours. I don't use it for anything other than the reception, but that's just because I try to shoot for the final output. I think that the ceremony footage will look really good when you compress it in post.
Looks like it was a great wedding for you.
Ben
Ben Lynn is offline   Reply With Quote
Old July 12th, 2007, 02:15 AM   #5
I used to use black stretch in low light but don't now because I found it made the blacks so noisy, especially when combined with gain. It means that only lower gain settings look acceptable. I also don't mind leaving the blacks black.
Old July 12th, 2007, 07:10 AM   #6
Hi ,
thanks for all those replies!
I used BS to bring down the iris a bit for wider latitude in the pic - perhaps it was too much, but I wasnt satisfied with the pic out of the cam - it looked Blackcompressed to me - so I went a bit "against" that look. Perhaps that was wrong, I know that IŽll bring the blacks back in in post again...
I must admit : On the TV screen the pics look much better than on the computer stills... CA and noise is less obvious with moving objects...
Uli
