Can I use the GY-HD111E With my JVC SD monitor? at DVinfo.net
Old July 28th, 2007, 03:45 AM   #1
Hi,
I am just about to take the plunge and go for the HD111E (UK model with FW in) and I have a quick question about monitors.
I have a 15" JVC TM-H150CG SD broadcast monitor (see spec at http://www.creativevideo.co.uk/publi...=jvc_tm-h150cg)
Y: 1.0 V (p-p), 75 ohms, negative sync
C:0.3 V (p-p), 75 ohms (PAL)
I am interested to know if I can use it with the HD111E and in what modes. It has BNC and S-Video inputs and supports 750 horizontal lines.
According to the JVC web site (http://www.jvcpro.co.uk/item/index_html?item=GY-HD111E) it has the following video outputs:
Analogue composite output: 1.0 V (p-p), 75 ohms, unbalanced (RCA)
Analogue component output:Y: 1.0 V (p-p), 75 ohms, unbalanced (RCA)
PB/PR: 0.7 V (p-p), 75 ohms, unbalanced (RCA)
Can anyone help?
Alex Wren is offline   Reply With Quote
Old July 28th, 2007, 05:22 AM   #2
Hi Alex - Yes you can use your JVC monitor but of course only in SD - we used to use a JVC TM140 to monitor with a JVC HD101E a while back - nice picture. However this was replaced with an 8.5" Sony HD monitor for location work.
If it's the same set up as the TM140 (sounds like it is) connect the camera and monitor via one lead (composite) phono one end (camera) to BNC adapter at the other (monitor) - is this the info you were looking for?
Regards: Stu
www.studioscotland.co.uk
Stewart Menelaws is offline   Reply With Quote
Old July 28th, 2007, 05:50 AM   #3
Thanks Stewart!
Yes this is exactly what I wanted to hear.
Out of interest will the HD480/60p mode work with the monitor or are all HD modes out of play?
Alex
Old July 28th, 2007, 06:16 AM   #4
I have the same JVC monitor and a 110U and they work fine together. I use a RCA to BNC converter and hook a BNC cable from the composite out on the camera to the monitor. All modes should work. However, the camera will convert it to 29.97 interlaced.
Matthew
Matthew Rogers is offline   Reply
