SD Card Limitations at DVinfo.net
Open DV Discussion
Old April 28th, 2010, 10:18 PM   #1
SD Card Limitations
Wasn't sure if this should go in the Panasonic forum or not...
Have an older PV-GS70 that the kids are now using but for some reason it will only record for 2 minutes straight to the 2GB SD card. Of course, the file size is way smaller than the card capacity...
Anyone have any ideas why it only records for 2 minutes before stopping? The manual/documentation has nothing to offer on this problem so I turn to the members of this forum who have so much experience and knowledge to share.
Any suggestions/ideas?
Tim Albert is offline   Reply With Quote
Old April 28th, 2010, 10:47 PM   #2
Is it a Class 6 card or faster? Some recommend a Class 10 card for the Sony EX1.
Dean Sensui
Old April 28th, 2010, 10:50 PM   #3
Images: 18
Hi Tim.............
First question:
When the camera stops after 2 minutes, when you hit record again, does it record another 2 minutes, or is that first 2 minutes as much as it will put on the card?
That will give us something to go on.
CS
Old April 28th, 2010, 11:07 PM   #4
Images: 18
Never mind............
Think I've cracked it.
Manual here:
http://studio.berkeley.edu/coursewor...ls/PVGS70D.pdf
Check out page 56: Recording moving Pictures.
2 minutes is your lot at Superfine or Fine. For more time you need to switch down to Normal.
Looks like our culprit but I'll let the jury decide.
CS
Old May 2nd, 2010, 02:23 PM   #5
Manual here:
CS
Chris, thank you very much; somehow we missed this piece of information in the manual but the change to "normal" has indeed fixed the problem. Not sure why this limitation exists if we are recording directly to the card, but if we are not it may have something to do with internal buffering or something.
Thanks again to you (and Dean) for taking the time to respond.
Old May 2nd, 2010, 02:52 PM   #6
Images: 18
No problem.................
Glad to be of service.
CS
Old May 10th, 2010, 10:15 PM   #7
"Some" includes Sony Sony : MEAD-SD01 (MEADSD01) : Features : Turkey
Jim Snow is offline   Reply
