Final Cut and P2 question - Page 2 at DVinfo.net
Old March 26th, 2006, 02:28 PM   #16
I'll admit that I haven't touched the camera for more than a week, but I have worked with it. 720p24 24PN is true 24 fps...because it isn't going to tape, there is no pulldown to remove. Why would there be pulldown to remove at 1080p24? Is there no 24PN setting for that? Guess not.
Then shoot 1080p24 and edit in a 1080p60 project.
Shane Ross is offline   Reply With Quote
Old March 26th, 2006, 03:55 PM   #17
MPS Digital Studios
I don't have it in front of me, but it's 1080i 24p only. Barry, can you fill us in on this, please?
heath
My Final Cut Pro X blog
Old March 26th, 2006, 04:54 PM   #18
Why don't you play a bit with the settings instead of waiting for an answer? If you don't see a nasty green/red/orange colour at the top of your timeline you're good.. ;-)
Vincent Rozenberg is offline   Reply With Quote
Old March 26th, 2006, 06:21 PM   #19
MPS Digital Studios
I wasn't in the office today, so to speak.
h
Old March 26th, 2006, 07:12 PM   #20
The reason there is no 1080pn24 and why 1080p is encoded into a 60i stream (as 480p24 is on the DVX100) is conformance with existing standards. The HVX200 uses the DVCPROHD codec, which allows for 720p and 1080i There is no support for 1080p directly, thus the 24p stream must be delivered over 60i. Creating a new version of DVCPROHD to accommodate 1080p would create a rift of incompatibility in the industry with the existing standard.
When you shoot 1080p, you still get true 1080p, you just need to run the proper pull-down to eliminate the duplicate fields and assemble progressive frames. The video is encoded over a 60i timeline, but the actual image data itself is NOT interlaced. There's no reason to take a 1080p24 project into a 1080p60 timeline unless you're intending to make use of the 60p frame rate for your project. However, since DVCPROHD does not support 1080p AND no support for 1080 at 24fps, you will have to transcode your video to another format like Avid's DNxHD or even uncompressed frames before you can work with your project in 24p.
- Jeff Kilgroe
- Applied Visual Technologies | DarkScience
- www.darkscience.com
Jeff Kilgroe is offline   Reply With Quote
Old March 27th, 2006, 02:00 AM   #21
Barry Wan Kenobi
I don't believe Apple has proper 1080/24p support yet. I believe Adam Wilt posted some technique for using cinema tools to remove 1080/24pa pulldown.
I don't think Avid has 1080/24p support either.
Canopus Edius does, and so does Raylight (but Raylight supports only 1080/24pA).
Old March 27th, 2006, 12:25 PM   #22
View my tutorial at www.proapptips.com/shane
It is called P2 INTRODUCTION.
hi shane,
watched your tutorial. brilliant. however, wondering though about capturinng (streaming) straight from camera to harddisk, ie. without P2 cards. have you tried this? what sort of experience?
cheers
tim
Tim Schultz is offline   Reply With Quote
Old March 27th, 2006, 12:48 PM   #23
MPS Digital Studios
It can't be done without a firestore.
hwm
Old March 27th, 2006, 01:17 PM   #24
It can be done without a Firestore, although I hear only in Video Mode, not Film Mode. But I might be mistaken.
No, I haven't tried it. Haven't had the need. The P2 cards work well for us. Plus I don't own the camera, my producer does. I just get handed the footage.
Old March 27th, 2006, 03:15 PM   #25
thanks shane,
we own the camera but not the P2s....just not cost effective for what we're trying to do. so, waiting for the firestore!
meanwhile....
just tested running straight to hard disk through fcp on a powerbook g4. it seemed to work fine (used video mode) both as firewire host and firewire device...is one of these better?
this seems to create a quicktime file in the fcp capture scratch folders, though doesn't save the whole thing as an fcp project....even though i save it as such in fcp itself. not a problem really as we've got our footage - works out at about 2min/gb.
so, tests seem to be going fine....will see if film mode works.
another thing: shooting direct to disk seems to work fine with OS.X.10.3.9 though you mention in your tutorial that it should be 10.4.3.....just an observation.
thanks again.
tim
Old March 27th, 2006, 03:38 PM   #26
I am talking about importing from P2, not direct to disk.
Although I have been told by many a folk that they were still running 10.3.9 and were able to import footage. I guess it is only the FCP 5.0.4 and QT 7.0.3 that are really required.
Old March 28th, 2006, 11:06 AM   #27
shane,
yeah, i think you're right. makes me glad i'm not importing from P2!
one thing that we did discover when shooting direct to disk (hard drive not firestore obviously) that was odd is that it seems to make no difference to quality of footage whether shooting in 'host' mode or 'device' mode. makes no difference to how FCP copes with it either.
any opinions as to which one we should go with?
thanks again
tim
