V1E - What is the progressive problem? - Page 2 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old October 16th, 2007, 01:31 PM   #16
Originally Posted by Alnoor Dewshi View Post
No. The issues have only been with the V1E and 25P.
This is not actually true. The "problem" is exactly the same, only less pronounced - but I did experiment with 30PsF raw files and they also showed some tendency for line twitter (by far less than the 25PsF stuff).
I'll repeat: the original problem of "oil paint effect" was spotted and then fixed on the PAL version only. The line twitter problem of PsF material (or rather displays failing to process it correctly) is common to all versions, only pronouced more on the PAL model because of what I wrote in my previous post. BTW, this is true about the PsF technology in general, and not V1-specific.
Old October 16th, 2007, 01:52 PM   #17
I stand corrected.
Piotr, this relates to my earlier question: Is the effect more pronounced when looking at the image at 1080i than at a downconverted to dv stream of the same content? Have you compared both on the same display?
Last edited by Alnoor Dewshi; October 16th, 2007 at 02:00 PM. Reason: Added a question
Alnoor Dewshi is offline   Reply With Quote
Old October 16th, 2007, 02:44 PM   #18
I stand corrected.
Alnoor,
Frankly, I never shoot SD or down-convert at capture; I do author SD DVD's from time to time, but I do it from the HD Vegas timeline.
And definitely not, in my SD progressive DVDs I never spotted the line twittering effect.
Old October 16th, 2007, 06:59 PM   #19
HDV Cinema
... therefore I'm either:
- burning to Blu-Ray as 24p, after having nested a ready 25PsF project in a new 24p Vegas project and stretched it precisely for time-matching, or
Burning the 25p within 24p sounds very interesting because once the 2-3 pulldown is added -- before recording to BD or HD DVD -- the transmission PATH is "interlaced" but any good display will auto-sense the 2-3 cadence and assume it is film. If a display correctly senses "film" it knows EXACTLY how to turn the "interlaced" input to 60p. (This will happen with any resolution monitor -- it need not be FullHD. It does need to offer 60p or 120p operation, however.)
Can you explain more how you do it. Does the audio pitch change?
Old October 17th, 2007, 01:49 AM   #20
Steve, let me link you to where Bob described it, as I learned from him:
http://www.sonycreativesoftware.com/...151&Replies=20
I believe he described the method in this forum as well, but cannot remember now where exactly.
Old October 25th, 2007, 10:13 AM   #21
Thanks for all the help
I sent my V1E back to sony and they changed the PCB - now all my problems are gone. phew...
Deniz Ahmet is offline   Reply
