PART 2: FX-1 Chroma Key GREAT RESULTS - Page 3 at DVinfo.net
Old November 16th, 2005, 04:10 PM   #31
Eric James
Top job looks excellent well done
would like to see more if you have any
Jim Rog is offline
Old November 16th, 2005, 04:22 PM   #32
Originally Posted by Eric James
I actaully never deinterlaced. Because it was shot in 1080i, once I bring it down to 720p there is no need to deinterlace.
Hi Eric, could you elaborate on this statement a bit more?
How did you convert 1080i to 720p and why your method does not require deinterlacing?
Alex Raskin is offline
Old November 16th, 2005, 04:27 PM   #33
Hello
can someone tell me the next best thing to final cut pro and shake that will run on windows?
Jim Rog is offline
Old November 16th, 2005, 04:49 PM   #34
If you divide 1080 by 720 you'll get 3/2. For every 3 Lines 1080i you get 2 lines 720p. That means the jaggy structure of interlaced lines is hidden by blending 2 lines from Field one and 1 from field two (or vice versa) to get two progressive lines. That means every line on the progressive image is a mixture of both fields. The only problem is that the first 2 lines on 720 p contain more of field 1, the next two more of field 2 and so on. It will be visible, but only in moving parts of the image and only if you look carefully. Far less obvious than the usual interlaced "look".
Thomas Richter is offline
Old November 17th, 2005, 09:51 PM   #35
What exactly did you use (software, plugin, ect...) to get the 720p, and is it basically 720p60 or 720p30 that you got from that? Footage looks amazing.
Noah Hayes is offline
Old November 18th, 2005, 10:57 AM   #36
Thanks Thomas!
Old March 26th, 2009, 03:49 PM   #37
Hi,
I cant see the videos... ot a codec problem, just a "Safari could not open the page “http://www.12in12.com/sincity/shaketreesincity.jpg” because the server is not responding."
Matias Baridon is offline
Old April 1st, 2009, 08:44 AM   #38
I literally can not see any of your links. I've tried many times, but from what you are writing I can imagine what this post is about. Is your video in black and white? (I'm guessing by the sin city title). A couple of times I have tried to use blue sheets or gym mats etc... to create blue screens. It did not work at all, and I will never try that again. Although the keys actually looked fine in black and white, but unfortunately the content didn't make black and white appropriate. Trying random greens or blues may work for some people in some situations, but the chroma color WILL work for all people. A cheap alternative is to go to home depot and have them match the color, then you can paint wood sheets or better yet canvas that you can roll up.
What shutter speed did you use? I always shoot w/ the shutter speed in 30 which has been reasonable to key. Last time I shot in 60 it was a nightmare. Obviously progressive is ideal, and I've recently been considering Cineframe 30 w/ my FX1.
I'd still like to see your work, so I'll check back soon.
Aric Mannion is offline
Old April 1st, 2009, 08:59 AM   #39
You guys are replying to a thread that's three-and-a-half years old... please check the date before responding. Safe to say that this one's got a lot of dust on it, so we're shutting her down.
Chris Hurd is offline
