Fx1 at DVinfo.net
Old June 25th, 2007, 01:55 AM   #1
Fx1
Hi again,
Just a quick question. When you plug in an external mic into the FX1, does it cut off the onboard stereo mic, or do both mics work at the same time?
Allan Sealey is offline   Reply With Quote
Old June 25th, 2007, 05:32 AM   #2
Yup, the internal mikes get cut off when you plug anything into the external mike socket, and you can't use internal on one channel and external on the other.
Tony Neal is offline   Reply
