ENG Lens compatibility at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old July 18th, 2008, 01:40 PM   #1
So people are reporting (thanks for the post Pete) that the Z7/S270 won't control the servo zoom on Canon/Fuji ENG lenses. This is pretty much a disaster considering that the camera is sold based on interchangeability.
Can others please confirm this?
I was really hoping to pick up a Z7 or the S270 and use my Fuji 17x as the stock lens is too short for my work.
Justin Ferar is offline   Reply With Quote
Old July 18th, 2008, 03:28 PM   #2
DVi Contributor
If by ENG you are referring to a B4 2/3rd lens. that is correct. there is not a port on the body for your control cable on that lens. the 1/2 inch (?) interchangable lens has control bottons located at the back of the mount. Thier is a step up adapter so you can mount 2/3rd lenes,, but all functrions become manual, and your focal field changes greatly.
Craig Chartier is offline   Reply With Quote
Old July 18th, 2008, 03:52 PM   #3
By ENG I'm talking about these lenses...
http://www.fujinon.com/Broadcast/Pro...ry.aspx?cat=28
They are all 1/3 inch HD ENG/EFP lenses. From what I've read the Sony has a 12 pin connection for lens control. I own the Fuji 17x but I haven't looked to see if it's 12 pin or not.
Old July 18th, 2008, 04:16 PM   #4
DVi Contributor
OK so the chip size is 1/3. I found the lens jack. it is a 12 pin, VERY COOL!!! hidden under the port cap on the side once you remove the Carl Zeiss piece of glass.
1/2 inch glass mounts with the Fujinon ACM-19 adapter
2/3 in lenses mount with fujinon ACM-17 adapter
I find new things hidden on this camera all the time. I wish they would make the pin port covers another color other than black so you can locate them quicker.
hope that helps
Old July 18th, 2008, 06:57 PM   #5
I can confirm that Fujinon lenses do work full servo. I've even used the Fuji 13x3.5BRM on the Z7 without any issues. Sorry I don't have a Canon lens to test.
Attachment 7719
Tim Dashwood
Old July 18th, 2008, 09:46 PM   #6
Attachment 7719
Very Cool!
Old July 18th, 2008, 10:33 PM   #7
Thread title changed from "No ENG Lens compatibility?!!" to "ENG Lens compatibility."
Old July 20th, 2008, 04:07 AM   #8
Thinking of buying
I am thinking of buying the 13x W/A Fuji zoom in the UK. Out of interest , how much does it cost in the US of A?
Cameraman BBC and ITV since 1966
Barry Wilkinson is offline   Reply With Quote
Old July 20th, 2008, 07:06 AM   #9
I have also been looking at this lens the cheapest I can find is here:http://www.macmall.com/macmall/shop/...rce=mwbfroogle
Old July 20th, 2008, 10:34 AM   #10
Questions
Its a shame it doesnt have a range extender. Any problem in buying in from the states? Do you have to pay duty ? Is the warranty void?
There seems to be no alternative as the Sony/Zeiss lens is only an 8 to 1 zoom. Maybe canon will provide soon?
Old July 20th, 2008, 09:48 PM   #11
Check www.resellerratings.com first.
Chuck Fadely is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
