CineForm support for Sony XDCAM EX - Page 6 at DVinfo.net
Old January 4th, 2008, 10:37 PM   #76
CTO, CineForm Inc.
Originally Posted by Christopher Barry View Post
David, the Patch is a dead link for me.
Also, is it the PHD install/build, the same for my P2K licence or do I need a different build? Thank you.
All new builds are now available at www.cineform.com.
Old January 4th, 2008, 11:13 PM   #77
CTO, CineForm Inc.
Link now fixed, and repeated here : http://www.miscdata.com/cineform/CFM...SourcePush.zip
Old January 4th, 2008, 11:37 PM   #78
So David, NEO HD is fully functional with the EX1 and Vegas?
Old January 5th, 2008, 01:09 AM   #79
CTO, CineForm Inc.
Yes. Even support HDSDI capture for keyer effects work if you need.
Old January 9th, 2008, 04:07 AM   #80
I downloaded the prospect2k trial and converted 720p25 clip to cineform. Clip plays trough in realtime in premiere CS3 but when I do cut and I basicly come into the clip when it is somewhere middle of it, the clip doesn't play real time anymore. This problem can be solved by exporting the clip where I am cutting out with clip where I'm cutting into one single prospect clip. But this is hardly a solution... since i can't possibly export every single cut I make just to see it in real time. Is my computer too slow to play it real time (core2duo with 2gigs of ram) or is this some sort of interframe codec problem?
Tuomas Sebastien is offline   Reply With Quote
Old January 9th, 2008, 09:48 AM   #81
CTO, CineForm Inc.
Tuomas,
It does sound like you don't have all our software fully installed or your are not using a CineForm preset. With 720p25 content on that PC you should be playing in realtime a half dozen layers, cutting wherever you want. Please submit a trouble ticket will www.cineform.com/support
