Adobe announces Native support for EX1 - Page 2 at DVinfo.net
Old April 16th, 2008, 05:24 AM   #16
I tested the update today and it works beautifully... until I try to export the movie.
What the heck are the correct settings? I simply want to save it as an avi but it refuses to give me anything playable - usually all I get is black screen for the duration of the clip.
What the?
John Hewat
Mammoth Media Productions
John Hewat is offline   Reply With Quote
Old April 16th, 2008, 09:39 AM   #17
Images: 12
What the?
I am not seeing any export problems. What settings are you using?
Randy Strome is offline   Reply With Quote
Old April 16th, 2008, 10:39 AM   #18
Originally Posted by Randy Strome View Post
You can import individual mp4 files or the whole BPAV folder. No need to convert to mxf or ever open clip browser.
Humm i tried to import a mp4 file directly from the BPAV folder, but premiere says its an unsupported file format (or damaged).
Did you do the same or am i missing a step?
Percy Tienhooven is offline   Reply With Quote
Old April 16th, 2008, 11:33 AM   #19
Images: 12
When I import the entire BPAV folder, Premiere gives a not supported message with ony the .smi file selected as not allowed. Press OK. All of the .mp4 files should import perfectly. When the individual .mp4's are selected, I get no error message.
Old April 16th, 2008, 01:02 PM   #20
So great that they offered Ex1 support now! Is that the Mainconcept plugin? After I have installed the Adobe update there was still that Mainconcept watermark form their Demo version on my preview monitor. After I removed that Mainconcept software also their logo was removed.
However, I also don't see and settings to export it as Ex1 MP4 file? How can I do this? Normaly I cut erverything I have filmed into shorter parts and export them, before I start working on the project. Often I have record 10 Minutes and need only 20 seconds of that clip. So I don't like to backup the whole 10 Minutes then. Therefore I need the MP4 export function.
Any idea where I can find this option?
Swen Goebbels is offline   Reply With Quote
Old April 16th, 2008, 06:50 PM   #21
I tried heaps of different settings - uncompressed, I don't remember what else. But I got blank screen... Anyone know why?
Or what settings I should be using?
John Hewat
Old April 16th, 2008, 08:19 PM   #22
Images: 12
Hi John, just to check, do you have the work area set to match your edited work. Sorry for the no brainer question, but hey, it happens.
Old April 16th, 2008, 10:04 PM   #23
Sure do.
It's not a no-brainer for someone like me. I'm always the guy who makes those mistakes. Rang a computer company the other day to yell at them for selling me a faulty firwire card. When they agreed to replace it, I looked one last time to see that the fault was me forgetting to plug the cable into the camera.
But as for these exports... no luck whatsoever...
John Hewat
Old April 17th, 2008, 03:16 AM   #24
XML Files
Hi,
Could someone please tell me what the XML files are when importing the BPAV folder into premiere, also why does Premiere report that certain files are not compatible, also I must be doing something wrong as I get the red render line across the timeline for all clips.
I recorded the footage in 1440x1080i 50 @ 25frames per second and I am using the SP preset - am I right with this.
Regards
Mike
Michael Gane is offline   Reply With Quote
Old April 17th, 2008, 03:40 AM   #25
Try renaming the files extension to .mpg
I had a similar problem with .m2t files in one of my computers. That solved the problem.
Jake Craig is offline   Reply With Quote
Old April 17th, 2008, 11:45 AM   #26
Again:
Has nobody here an idea how to export the clips as the same mp4 format the Ex1 record? The Mainconcept plugin offerd this, but it allways crashed after some minutes :-(
Old April 17th, 2008, 04:02 PM   #27
Originally Posted by Swen Goebbels View Post
Again:
What I can suggest you, is to follow a different workflow, the end result will be the same.
1.- Import all your clips to Premiere.
2.- Select the parts that you will use from each one of them on the source monitor window, NOT on the timeline.
3.- Save the resulting clips with a different name.
4.- Under the project menu, go to project manager and make sure that the following options are selcted. Create a new trimmed project and EXCLUDE UNUSED CLIPS and rename media files to match clip names.
5.- Click OK and Voila ! New project only with the footage that you actuallly need.
Old April 18th, 2008, 07:05 AM   #28
Well, still no luck exporting the finished product as anything watchable.
Interestingly, PPro 3.2 is on my two PCs. On one, the footage imports just fine and works beautifully (except for the exporting business)
On the other, I need to change the file type from mp4 to mpg for PPro to see it as compatible! After doing this, when putting the footage into the timeline it requires rendering.
However, on both computers, I was unable to see an exported video - it's just a black screen. Also, the Export-> Movie defaults to Microsoft DV AVI - why on earth would it do that instead of default to appropriate settings?
This thing bites. Cineform is worth the money. If Adobe could do it right from the start I'd be so much happier...
John Hewat
Old April 18th, 2008, 08:31 AM   #29
Images: 12
Hi John,
I am thinking that you have a bad install or some odd conflict. I would get on the horn with Adobe. You may also wan to try a uninstall/reinstall. You should not have to change file types to view in the timeline. Have you tried export > media encoder?
Old April 18th, 2008, 08:36 AM   #30
Hi John,
Yes, with H.264. But I don't want to be doing that, I just want plain old AVIs.
What do you think I have a bad install of? the update? or CS3 to begin with?
Whichever the case, what does that even mean? How can an install go bad??
What settings should I be using for correct output?
John Hewat
