What's the Best Format for Stock Footage??? - Page 2 at DVinfo.net
Old January 10th, 2009, 06:07 PM   #16
Doubt this will help but we feel you should be driving on the right hand side as well.
That is quite funny. But it misses the point. I should be more clear. In the UK, and indeed most of the world, TV's can accept most standards. So I could put an NTSC signal into my TV and every TV I have owned for a good many years and it would display it just fine. But in the US they take exactly the same TV models as the ones we can buy over here but they take out the ability to display PAL and other 50hz signals. I can only assume it is a lame anti-import measure. But it is totally at odds with most other countries TV's which can accept both 50hz and 60hz signals.
Simon Wyndham is offline   Reply With Quote
Old January 10th, 2009, 06:53 PM   #17
It does miss the point and I do agree with you.
We should be able to drive on the right hand side and the left hand side at the same time!
Old January 11th, 2009, 03:48 AM   #18
It would be fun :o) Then we should put the steering wheel in the middle. How about 27.5P
Old January 11th, 2009, 03:54 AM   #19
PAL, NTSC, PAL, NTSC ............ PAL, NTSC ....????
This has been a stumbling block for me for the last four years, I have purchased several software conversion applications to take PAL footage to NTSC - none of them with any great sucess. Now I have the EX3 and I can switch to whichever I want. Currently I am shooting in NTSC as the US market is big for my project.
I was surprised that with the introduction of HD that manufacturers didn't standardise on a viewing format as well, but then they spent so much time trying to make up their minds on Blu-Ray or HDTV that they forgot about the basics.
Oh well, as Simon says, NTSC can be played on PAL sets - even if does mean slightly lower resolution, but then the HD to SD downconversion is not producing 100% satisfaction anyway. (at the moment)
Old January 11th, 2009, 07:34 AM   #20
???? You mean your country puts the consumer's needs ahead of corporate needs???
What a novel idea?
John
John Peterson is offline   Reply With Quote
Old January 11th, 2009, 08:00 AM   #21
Nothing to do with the country. The manufacturers just enable TV's and equipment to accept all signals. In the US I don't know who makes the decision, but they cut out the ability to display 50hz video.
Old January 11th, 2009, 01:00 PM   #22
Also note that in PAL countries most DVD players can play both NTSC and PAL DVDs.
In the good 'ol days the frame sizes were different too.
PAL
625 lines or 576
NTSC
525 lines or 486
In HD world everywhere
1280x720
1920x1080
Now if all sets could handle
24p, 25p, 30p, 50p, 60p, 50i, 60i, we'd be "golden"
but crikey you'd still have a bloody mess in your NLE timeline.
BTW All this really means that NTSC frame rates are the only one's that play everywhere as long as USA TVs can't play PAL frame rates.
Old January 11th, 2009, 01:34 PM   #23
And I thought it was more to do with the countries voltage 50hz UK or 60hz USA (I know the power is measured in Watts)
Old January 11th, 2009, 04:04 PM   #24
My experience in the US has been that most of the more recent big brand name TV's (Sony, Panasonic, Samsung) etc do support PAL via the composite or component input, the same goes for the big brand DVD players, many do play NTSC. The problem is with the huge numbers of TV's and DVD's made by companies we do not see in Europe such as Magnavox, Vizio, Polaroid, Emerson and so on. These sets are sold in their millions in stores such as Wal-Mart and are very much NTSC only.
All the DVD's that I have released for worlwide distribution have been NTSC as a result. With HD this should be less of an issue as modern HD LCD's and Bluray players are more than likely to support both 25P and 30P, at least now the frame sizes are standard around the world.
Broadcast however is a different matter as TV stations are often transmitting in both HD and SD, so the frame rate must be correct for the SD PAL or NTSC transmission.
Old January 15th, 2009, 07:53 PM   #25
One More "Recommendation"
In regards to the frame rate/type for stock footage, this is what I got from AlwaysHD:
"As far as "best format," we used to say 1080 p30 because it allows for the greatest number of easy conversions, but lately there seems to be a trend toward 25p and 24p. I definitely lean toward progressive over interlaced."
As stated in previous posts, it seems to be unanimous to go with progressive (not a surprise), but as to the frame rate its either 24, 25, or 30p. (As for me, I'll probably default to 30p in part because I've started some projects in that format, but if I have time I may shoot some 24 or 25p as well - gotta love the flexibility of the EX1 and EX3.)
Sony EX3, EX1, FX7, CX7, HC3, Vegas 8.0
www.pronghornproductions.com
Dan Licht is offline   Reply With Quote
Old January 18th, 2009, 09:54 AM   #26
Thought I'd offer an alternate opinion.
I prefer 1080i because it seems to handle slow motion a lot better. 30p gets real strobey looking at around 50% speed. 24p is almost unwatchable at 50% (depending on the content of course).
Craig Terott is offline   Reply With Quote
Old January 18th, 2009, 10:11 AM   #27
Key is temporal resolution for what you're doing. 60 "units" per second allows for higher number of "snapshots" per second so there's more "snapshots" in the slow mo. Optical Flow filter would have more to work with for example.
Actually for that reason 720p60 is good for slow mo since you start with 60 progressive frames.
Old January 18th, 2009, 11:27 AM   #28
If you feel like that in the US, just think what other European countries feel... :-) I remember being told years ago that the golden opportunity that was missed was immediately after the Second World War, when there were very few private cars on the roads, most of the street signs had been taken down, and there were no complicated road junctions so it would have been fairly easy (and cheap) to do.
But at that time the extent to which cars and lorries would cross the English Channel couldn't be even dreamed at, and most of the car export market was to other left hand driving countries anyway, so it didn't seem worth bothering with. By the time it came to be seen as a good idea in principle, the cost of adapting complex road junctions alone effectively ruled the idea out.
But to come back to video, then whereas with cars there is no intrinsic advantage to driving on the left or right, there are advantages to 50Hz systems over 60Hz ones. There's no such thing as DF TC in 50Hz systems (whew!) and a much easier releationship between real time and no of frames. If 4% speed up/down differences are accepted, there's also no problem with showing film on TV without having to use 3:2 pull down.
About 25 years ago there was a US proposal for a worldwide TV standard based on 1125 lines and 40 frames/80fields/sec interlaced. Regrettably, it never got taken up, especially since by now it would probably have evolved into 1080p/40 - much better motion rendition than any of 24,25 or 30 progressive fps, yet more technically practical than 50 or 60p.
For the full story see EBU Technical Review , then "HDTV" under "Hot Topics", then article 311 - "The development of HDTV in Europe — a tale of three cities: Dublin, Dubrovnik and Geneva"
Richard Green, then Director of the ATSC, the body set up to devise a US standard for terrestrial HDTV broadcasting, suggested that a worldwide (interlace) HDTV standard might use 40Hz (80 fields per second). This could then allow lower cost and higher quality standards conversion to both the 25Hz and 30Hz worlds. It would have a high “interlace factor” and the pictures would look similar in quality to progressively-scanned pictures. Standards conversion can be done easier if you convert down from a high to a lower frame rate.
Old January 18th, 2009, 01:05 PM   #29
Interesting stuff, from a historical point of view. I always wondered why my steering wheel was on the right hand side and if only that 40mhz standard was adopted, just think I could have been driving on the right hand side at 40 mph instead of a juddery 30 mph.
Not sure where this has got us in terms of knowing what frame rate to shoot at. Perhaps the best thing to do is ask your stock library what format they want the footage in.
Old January 18th, 2009, 07:08 PM   #30
Was the answer supplied by the earlier poster (via his stock agency) that 30p might be the best an accurate answer? It also sounded like they were leaning toward 24/25p, though. But it sounded like 30p had the easiest jump to other formats.
Dave Morrison is offline   Reply
