Corrupted BPAV folder (Any fix?) - Page 2 at DVinfo.net
Old March 3rd, 2009, 02:07 PM   #16
No I don't, there have been files come and go since the footage in question was shot.
Roger Akers is offline   Reply With Quote
Old March 3rd, 2009, 04:04 PM   #17
Try using clip browser to import the MP4's. Go "File" and "import" and navigate to the CLPR subfolders to import the MP4's. This should create a new BPAV folder with all the necessary files.
Old March 3rd, 2009, 06:33 PM   #18
^^^^that sounds promising^^^^ (waiting patiently to see it that's a fix or not)
Sony EX3, Canon 5D MkII, Chrosziel Matte Box, Sachtler tripod, Steadicam Flyer, Mac Pro, Apple/Adobe software - 20 years as a local videographer/editor
Mitchell Lewis is offline   Reply With Quote
Old March 4th, 2009, 08:00 AM   #19
Seemed like a promising idea but didn't work. Said "failed to import file".
The footage is sitting right in front of me and I cannot view it. I'm at a loss at this point.
Old March 4th, 2009, 08:09 AM   #20
Bummer.....sorry Roger. :(
Old March 4th, 2009, 10:07 AM   #21
Images: 10
I guess you can play the footage in VLC and MPEG StreamClip though...
Old March 4th, 2009, 02:47 PM   #22
Have you tried an mpeg restore programme? very often the media is in tact but the "headers" or "atoms" as I think they are refered to, are missing. I read something recently about this, and if the latest version of VLC won't play the mp4, then I'd say it's pretty sure they are damaged.
It's quite right about Edius, it has no interest in the file structure, you can lift an mp4 out of a BPAV folder and play it direct.
Do you have a small damaged mp4 file you can upload? I'm game to attempt a recovery.
Paul
Another Sunny Day in Ibiza
Paul Newman is offline   Reply With Quote
Old March 5th, 2009, 10:48 AM   #23
Paul thanks for the response. Currently I'm home sick from work, but I can swing ya a small mp4 tomorrow. If you have any luck then I could try to reproduce the fix on my larger files.
Old March 5th, 2009, 11:22 AM   #24
try MPEG editor and DVD editor- Womble Multimedia, Inc.
that has a few mpeg fixing tools - u can d/l a full version for limited trial time
simply drag the mp4 file into the play window
Matt San is offline   Reply With Quote
Old March 6th, 2009, 02:22 PM   #25
Bonanza. FIXED (for those that maybe have the same problem)
I "moved" (not copied) the folders in question to another hard drive then used NTFS Undelete — free, easy to use undelete software on the original hard drive to restore the files. After restoration it completely worked and I'm completely baffled as to why it did.
So if anyone finds this thread in the future, perhaps this unorthodox method might work for you.
Old March 6th, 2009, 02:35 PM   #26
Congrats, Roger, on the fix.
Just to clarify: Is is scaremongering or is this warning in the Clip Browser manual accurate:"To archive media from an SxS card to hard disc or other media, the Sony XDCAM EX ClipBrowser application must be used. Copying individual clips via the Macintosh Finder will
result in unusable media on the target drive."
If so, does that mean that I can't use my MBP G4 non-Intel in the field to copy files, as there's no Clip Browser version for it?
(XDCAM EX Browser for Mac Version 2.0, Mac Requirements: OS: OS X 10.4.10*, CPU: Intel Core 2 Duo 1GHz or higher)
Mike Chandler is offline   Reply With Quote
Old March 6th, 2009, 06:51 PM   #27
Wow Congratulations
That info should be made a sticky on this site that's incredibly valuable.
Thank you Roger
Old March 7th, 2009, 12:02 AM   #28
CRC Check. ALWAYS.
http://www.dvinfo.net/conf/1023724-post5.html
Craig Seeman is offline   Reply
