Shooter is PC | Editor is Mac - Page 2 at DVinfo.net
Old July 8th, 2009, 02:19 PM   #16
Originally Posted by Ed Kukla View Post
the macdrive people said I could not do clipbrowser on a pc, moving clips to a mac formatted hard drive. Were they wrong? Overly cautious? I repeated the question back to them to make sure I wasn't misstating the issue and they were insistant macdrive and clipbrowser are incompatible.
After not being able to transfer using Clipbrowser, that's what they told me, too. Maybe it's because I was going Firewire, not usb.
www.packcreekproductions.com
EX3, Mac Pro, FCP
Mike Chandler is offline   Reply With Quote
Old July 10th, 2009, 02:48 AM   #17
I think you are making this into a bigger problem than it is. The filestructure of the BPAV-folders has nothing to do with wheather you are on a Mac or a PC. The only problem you could run into is the Mac not being able to read the file system of the drive. FAT32 would be the solution to this. The EX1/3-files don't ever exceed the 4 GB limit, even after combining clips. An NTFS-drive should also work. As long as you do not need to write to the drive the Mac should be able to read NTFS-drives.
Ola Christoffersson, Kamrat produktion, Stockholm - Sweden
www.kamrat.tv
Ola Christoffersson is offline   Reply With Quote
Old July 10th, 2009, 03:51 AM   #18
Not true; when you record for long enough withoout pausing, a lot of <4GB files will be created on the card; after copying to the same BPAV directory on an NTFS drive, a single clip of a size much exceeding 4 GB can be created.
For instance, my over 1 hour live music shots usually result in >20 GB clips.
Old July 10th, 2009, 05:17 AM   #19
Not necessarily true. And hasn't been true in my dealings with Mac folks. However, I did find this:
Apple - Downloads - System/Disk Utilities - NTFS-3G
So it looks like a solveable problem. I wish I had known about this utility before I spent money on Macdrive, but Macdrive still works nicely, and is convenient for me to have.
Old July 10th, 2009, 08:35 AM   #20
I decided to try MacDrive again, and this time it worked. Don't know if it's because I bypassed the express card/firewire adapter and used usb instead, or whether it's because it was MacDrive 8 vs. 7, but the pc laptop is indeed seeing the mac formatted drive and clip browser is copying the bpav folder.
It's not playing the clips, but I think that's a function of the netbook capabilities (Lenovo S12).
EX3, Mac Pro, FCP
Old July 11th, 2009, 02:57 AM   #21
I should really test this before posting again but I guess I have to live with the shame if I turn out to be wrong anyway...
Piotr - you may very well end up with "clips" that are larger than 4 GB when browsing in Clip Browser or after importing into your editing software or exporting as MXF. BUT as long as the files are native EX-files in a BPAV-folder the FILES should not exceed 4 GB. The metadata informs the system of which 4 GB files should be combined to play back your 20 GB Clip.
www.kamrat.tv
Old July 11th, 2009, 02:59 AM   #22
Of course this is not true of all versions of Mac OS. I don't know when the Mac became able to read NTFS but I have not had a problem moving a NTFS-disk back and forth to a friends Mac and he is running some flavour of OS X.
www.kamrat.tv
Old July 11th, 2009, 03:24 AM   #23
Ola,
This is an academic discussion; of course on FAT32 media (like the SxS), you cannot exceed the single file size limit.
I was talking about results of combining folders on your non-FAT32 HDD using ClipBrowser (same occurs when you just copy the same take's chunks into the same directory; of course using ClipBrowser, not your OS's tools).
If I mentioned it, is because to me it's important to have each take in a single (however big) file. Editing music videos, I need to cut/split the clips where the music requires it; also I'm usually edit in multi-camera mode. You can realize how many split/cut points I'm getting; to keep things tidy I prefer that there's no additional splits due to any files size limits...
But re: the original thread subject, you're of course right; as long as any single file size is within the FAT32 limits, there should be no probs exchanging them between the two platforms (and using the right tools).
