Odd EX1 focus incident at DVinfo.net
Old June 28th, 2012, 05:01 AM   #1
Hi there
I use My EX1 lots and an odd thing happened last week. I turned the camera on and everything through the lens was very out of focus. If I zoomed right in, things would come into focus at about 80% zoomed in before going out of focus again as i continued to zoom to 100%. Obviously I freaked out (internally) as I was with a client at the time.
I turned the camera off and on again and hey presto, all was good again! Ive used the camera on another day of shooting since (with lots of turning on and off throughout the day) without an issue.
Has this happened to any other EX1 users?
I hope it's not the beginning of the end of this camera as I've become a bit emotionally attached to it....but that's normal...right?
Cheers
Jamie
Jamie Roberts is offline   Reply With Quote
Old June 28th, 2012, 05:40 AM   #2
Re: Odd EX1 focus incident
Yes, this randomly happened to my EX1R earlier this year. http://www.dvinfo.net/forum/sony-xdc...concerned.html
Clean power could be the key here. Any abrupt shutdown or dirty power will cause the backfocus to completely screw up and be unrecoverable until a reboot.
This was when it was under 100 hours of use. I'm closing in on over 200 hours on the hours meter now.
It is important to set your backfocus every once in a while. Go into the EX1's maintenance menu and do a "Auto FB adjust" on a Siemens star or a textured surface. This is clearly a backfocus issue.
Old June 28th, 2012, 08:59 AM   #3
Jamie
Mine did it once about two years ago. Has never happened again. I think a few people have experienced it.
Likewise the white balance sending everything bright green problem some have reported. Happened to me a couple of times with no lasting effect.
I think it's just a software glitch that happens very occasionally. Nothing to worry about.
Marcus Durham
Media2u, Corporate Video Production For Your Business - http://www.media2u.co.uk
Marcus Durham is offline   Reply With Quote
Old June 28th, 2012, 09:24 AM   #4
I agree with you that it freaks the hell out of you when it happens especially in an event video! I do not believe it has anything to do with the back focus - either wise it will not come back to normality without an FB adjustment.
What I would like to add is that sometimes powering down and up again is not enough. I found out that it's best to:
1) stay calm
2) power down
3) remove completely the battery
4) re-insert battery
5) power up
Happens on EX1, EX1r and EX3s...
Brian Cassar is offline   Reply With Quote
Old June 28th, 2012, 06:13 PM   #5
Thanks guys. Comforting to know it's no big deal.
Marcus I had the 'green' thing happen during white balance a couple of times when I first got the camera...that was a bit freaky too! It only seemed to happen when I white balanced using newly painted white weatherboards at my house...something in the paint?
Good advice Brian.
Jack I'll give that a go if it happens again.
Cheers
Jamie
Old June 28th, 2012, 07:09 PM   #6
Jamie,
I have an EX1 in the L.A. shop at the moment for repairs for the following 2 symptoms:
Issue 1. Lens Fragment Problem:
While shooting a light colored subject like a blue sky, or solid white subject in both telephoto & especially in the wide position, and with the iris settings of 16, 13, & 11, there is a purple “string” looking object that appears at the lower center third of the screen or 6:00 position. It is present in higher f-stops, but is far more noticeable when using lower iris settings.
Issue 2. Focus Problem:
When I perform a slow zoom in or out to max position, with the top handle rocker, or the hand grip servo zoom rocker, then start to zoom out at a medium or super fast speed, (like to re-set a shot) the image goes completely out of focus for a fraction of a second; almost like a brief "focus blooming" effect. This symptom occurred a couple of months ago to present.
I use all manual settings as a videographer, so I always have the focus, iris, white balance, everything set to full manual mode.
Sony concluded that the "Prism Block" will have to be replaced. Part cost: $1,050.00. Not including labor. That being said, the manager at Sony was very nice and they are working to get the camera back asap. This is suppose to take care of both issues....
Also, they will update the firmware from 1.11 to 1.30 (the latest I believe).
Joel Brooks
Moments In Time Video Productions
Joel Brooks is offline   Reply With Quote
Old June 29th, 2012, 12:26 AM   #7
Ouch! How long will it take them to fix it Joel? Is there labour costs on top of that?
Old June 29th, 2012, 01:16 PM   #8
Jamie,
Yes. Nearly $1,500.00 total. I am told it could have cost more than that. I have been without my cam for 2 weeks now. It should be done about another week or so.
Joel
Old June 29th, 2012, 10:03 PM   #9
I am SO happy that I was still under warranty when I discovered a bunch of crud inside my prism block. Like you, I discovered the junk was in there only after I stopped the lens down close to f11 or f16 and pointed it toward the sky. They also replaced a lens or two.....thank goodness for the extended Sony warranty.
Old June 29th, 2012, 10:57 PM   #10
Fortunately, I only have a dust problem on the UV filter. But hearing of prism dust is making me a little uneasy...
Jack Zhang is offline   Reply
