One color pop - the rest desaturated - fastest method? at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old May 14th, 2007, 06:43 PM   #1
Anybody using a quick method to keep, say, a model's lips red and the rest of the frame desat/b&w without overlays?
Or is the overlay still the fastest way to go?
Chris Leong is offline   Reply With Quote
Old May 14th, 2007, 06:50 PM   #2
in FCP (not sure what you're using), you would select a "limit effect" on a color correction pushing the saturation all the way down.
Web Youtube Facebook
Cole McDonald is offline   Reply With Quote
Old May 14th, 2007, 06:55 PM   #3
Thanks Cole
I have both FCP and Avid. The Avid MC I'm using now at work doesn't have that setting, but maybe XPress HD does too?
So you just dial up the chroma value you wish to protect and then desat the rest of the image, right?
Cheers
Chris
Old May 15th, 2007, 06:36 AM   #4
You would make sure to exxaggerate the lips slightly using makeup to make it "pop" from the flesh tones. Then desaturate the entire image, select the limit effect section at the bottom of the Color Corrector, pick your reds and invert the limit:
http://www.izzyvideo.com/2006/11/04/...aller-version/
Old May 15th, 2007, 02:22 PM   #5
Success!
Thanks, Cole!
Cheers
Chris
Old May 15th, 2007, 04:55 PM   #6
post before and after clips :)
Old May 15th, 2007, 05:42 PM   #7
Cole, I've never tried that before. What's the best size/compression rate etc for posting to this board? (FCP 5.1.4 with everything on it, also QT Pro on dual G5 system, so I could make almost anything, I'd guess. HDV origination)
I guess the clip would be around 15 secs, give or take.
Cheers
Chris
Old May 15th, 2007, 06:04 PM   #8
I would say anything single digit in Mb would be fine (10Mb or less). for pix, I like to just use 640x480ish jpgs. Vid, you'll have to host yourself seomwhere. Megaupload seems to be popular (I don't like it personally, but I've got my own serverspace-extra clicks bad)...there's a few others too.
Old May 15th, 2007, 06:08 PM   #9
FWIW, you can do this sort of effect in-camera with the Sony Z1 (and maybe the V1 and A1 as well?) using the "color correction" menu.
Old May 17th, 2007, 11:34 AM   #10
Overcast day, around an hour after sunset..
35mm DOF Box but with the GG spin turned off (not turned on yet).
Also, sorry about the compression on the jpeg. Have a real nice looking (5MB) file if anybody would like to see it...
Cheers
Chris
Old May 18th, 2007, 06:50 AM   #11
very cool looking. Nicely done.
Old May 18th, 2007, 01:36 PM   #12
Thanks to Cole and the gang!
The shot itself is a 15 second long diagonal wipe. Pretty darned effective and, as they say in Latin, QED.
(Quite Easily Done)!
Thanks again!
Cheers
Chris
Old May 30th, 2007, 06:46 PM   #13
Anyone know how to do this in Sony Vega Platinum? Or Adobe Premiere Elements?
Joshua Fernandez is offline   Reply With Quote
Old June 5th, 2007, 04:52 PM   #14
Joshua,
Check the Vegas forum. I know I've read it over there.
I've tried it, and it works. Cole's right about emphasizing the color to be isolated first.
As I recall, it was using the the secondary color corrector and desaturating all except for????
Here's a recent thread with a sample of the effect.
http://www.dvinfo.net/conf/showthrea...=Pleasantville
C100, 5DMk2, FCPX
Old June 5th, 2007, 05:25 PM   #15
Joshua,
Go to http://www.jetdv.com and search 'color pass' or 'pleasantville effect'. There is a quick process outlined in the Vol. 1 #11 Newsletter.
C100, 5DMk2, FCPX
Ken Diewert is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
