Duplicator Problem at DVinfo.net
Old April 6th, 2016, 03:48 AM   #1
Duplicator Problem
I have an Acard 1-7 Duplicator which is about 9 years old & works fine when I use Data-rite DVD-R 4.7gb 16x Full Face Printable, however, I`ve been told that this company has ceased producing these discs!
I have tried using Traxdata 16x & Sony 16x but when I do so the machine throws them out as a fail! They all work fine in one of my PC`s so I`m not suspecting that they are the cause.
I have checked on the Acard site & I have the latest firmware, I have also set the machine to "DAO" not "TAO" and tried various read & burn speeds, still without any success!
So does anyone have any ideas as to how I can fix before I have to shell out for a new one?
Thanks guys.
Barry Hunter is offline   Reply With Quote
Old April 6th, 2016, 06:13 AM   #2
Re: Duplicator Problem
Each of of the burners might need a fw update
reset controller to default
Bruce Dempsey is offline   Reply With Quote
Old April 6th, 2016, 06:49 AM   #3
You had me worried there Barry, same duplicator probably about the same age, with original drives and with same firmware, the only discs I could get last week were Traxdata 16x - just tested and working fine - Whew!
https://www.foxvideo.co.uk
Dave Farrants is offline   Reply With Quote
Old April 6th, 2016, 11:13 AM   #4
I`ve gone through the various menus but can`t find where you can reset to default, any ideas please?
Old April 6th, 2016, 11:16 AM   #5
There is no reset, fairly sure we have the same machine.
Correction - Menu 12-10 Resets to Default. (Manual page 83)
Old April 6th, 2016, 11:20 AM   #6
There is a 'hidden' menu - Press ESC for 2 seconds, takes you to Menu 12.
(Interesting Fact - 12-16 tells you how many discs burned and how many failures, I never knew that!)
Old April 6th, 2016, 12:33 PM   #7
Thanks for trying Dave, although my machine must be slightly different as 12-16 is "Update Firmware" which I tried using a disc I had created a couple of years back when I downloaded a FW update 1.75A which is the latest for this controller, circa 2007. No good though as when I tried test & copy if said source disc fail!
Old April 8th, 2016, 08:46 AM   #8
Decided on replacing the unit! Tax deductible etc I had got in contact with Acard in California and he said that he could supply a new controller etc but then I found a company here in the UK who could supply me with a new unit already built with 7 Pioneer drives for £307.00 so that`s what I did. Just tested it using AONE discs & it worked perfectly!
So if anyone needs the old unit (which still works if you can find compatable discs) or to use as spares etc, just get in touch!
Old April 10th, 2016, 08:05 PM   #9
Good idea Barry. A clean slate is what you needed.
The problem with an old duplicator is that when you try to fix one small error, all of a sudden you have seven more!
Cheers
Tim
Tim Lewis is offline   Reply
