Alternative sticks for Sachtler Ace Head - Page 2 at DVinfo.net
Old March 11th, 2013, 02:55 AM   #16
Vitec Group
Re: Alternative sticks for Sachtler Ace Head
Then, look at the price point. A set of sticks and a head, with "Sachtler" stamped all over, for $500 plus change?
Even a half wit would have to know that, as the opposition isn't in the habit of studding their kit with diamonds or finishing them in gold foil, anyone buying an ACE is buying into a shed load of design and operational compromises, just on the basis of price
Hi Chris,
The "buying into a shed load of design and operational compromises..." needs an answer. We got lots of feedback from Ace user. They are all impressed how much functionallity they get at this price point. We would not have launched a product with design and operational compromises. It is a Sachtler product and people can/will expect a head with high functionality. The Sachtler 75 mm tripods all have the advantage of being very compact and lightweight.
Barbara
Barbara Jaumann is offline   Reply With Quote
Old March 11th, 2013, 06:50 AM   #17
Thanks Barbara. I thought the specs looked the same but wasn't sure if the minimum weight would be the same. I'll take a look at what complete systems you have for the DV10 SB.
Garrett Low
www.GLowMediaProductions.com
Old March 11th, 2013, 11:56 AM   #18
Thanks, Barbara! You are a "stand-up" lady. We'll be doing business again.
Best regards,
J.
James Kuhn is offline   Reply With Quote
Old March 17th, 2013, 10:46 PM   #19
Boy! Do I know how to shut-down a conversation, or what? I'm beginning to get a complex. : )
Regards,
J.
Old May 4th, 2016, 08:16 PM   #20
Hi there,
Hope this hasn't already been covered, but I have Manfrotto 535 sticks that I'd like to put a Sachtler Ace L video head on. Do you know if this combination would work? (In terms of fit in the bowl and also tripod legs being able to close properly)?
Thanks.
Sarah Abbott is offline   Reply With Quote
Old May 4th, 2016, 09:36 PM   #21
I don't have the Ace L, but the 535 legs were a big improvement for my Ace M. They are sturdier, have less kickback on pans, go both higher and lower, etc. Is the L the same as the M only with CF legs? Unless the L has a much larger level adjustment knob than the M (and they look very similar in the photos) it should fit just fine.
David Dixon is offline   Reply With Quote
Old November 24th, 2016, 02:04 AM   #22
Does anyone know if it is possible to buy only the Ace L head (Canada/US) and not as a kit with the tripod? Can't seem to find a seller. I'd like to pair it with Manfrotto 535 sticks. Thanks.
Terence Morris is offline   Reply
