Table of Contents list at DVinfo.net
Old August 13th, 2008, 08:44 PM   #1
How do I create a Table of Contents/track list that I can then paste into another program (MS Publisher) from the named markers in DVDA 5?
Dan Bridges is offline   Reply With Quote
Old August 14th, 2008, 03:03 AM   #2
Old Boot
Dan, I'm assuming you have the original Vegas Project? Check out the Edit Details View for MARKERS and copy paste that? Dunno about doing this from within DVDA, what ever flavour . .?
Grazie
Old August 14th, 2008, 05:57 AM   #3
Graham, unfortunately that did not work. It shows 298 tracks but no marker labels.
Old August 14th, 2008, 07:05 AM   #4
Old Boot
Can you SEE the Markers in Vegas? Where did the marker labels come from? Now I want to understand this.
Interesting
Grazie
Old August 14th, 2008, 04:21 PM   #5
Interesting
Grazie
I manually entered them ("M" key) to indicate the start of new items in a live concert recording.
Old August 14th, 2008, 11:37 PM   #6
Old Boot
Wow! 298 Tracks!?
Dan? You entered them manually IN Vegas? Then you WILL have a list of these markers in Edit Detail View. I checked this yesterday. Make sure you use the Drop-Down menu in Edit Detail View to select Markers.
It was then a simple case of Highlight the info > Copy > Paste - and for my test it went straight into MS Notepad.
It does work. If not then I am still interested.
Grazie
Last edited by Graham Bernard; August 14th, 2008 at 11:40 PM. Reason: I missed additional info and comment
Old August 16th, 2008, 03:22 AM   #7
Wow! 298 Tracks!?
Grazie
Thank you for the guidance, Graham. That's what I want. I would have not have thought to look there without someone pointing it out.
Old August 16th, 2008, 05:02 PM   #8
Some further observations. I had an out-of-sequence marker, #28, between #7 & #8. (I found out afterwards that I'd missed the start of another track). Well, when I rendered to mpeg-2 and opened it in DVDA 5, the markers were renumbered correctly, with #28 becoming #8. Also, in Vegas 8, using Graham's method of getting a list of marker labels to use as track names, marker #28 was in the list as the 8th item, so it was usable without needing to be relocated.
Old August 16th, 2008, 06:53 PM   #9
Hi Dan. If you ever want to reorder the markers in Vegas so that the numbers are in running order, there is a way to do it.
In the Edit Details window, with Show Markers selected, select all the rows and then Ctl-X to cut them, then Ctl-V to paste them back again. When they are pasted back they willl be in sequence. Try it out on a dummy project first until you see how it works, because you can't undo this.
Richard
Richard Hunter is offline   Reply With Quote
Old August 16th, 2008, 08:49 PM   #10
Richard, I've tried this in Vegas 8b and it doesn't seem to work. In Edit Details | Markers, I see two columns: Position; Name. I can select a range in a column using the shift-key, and using this at the beginning & end of a column, I can select the whole column, but I can't select both columms at once, nor can I use Ctrl-A to select everything. Furthermore, once selected, while copy & paste are available, cut is grayed out.
Correction: just found out how to do it. You need to select the range of gray numbers on the the left. That selects both columns and you can then Ctrl-x. See example:
Old August 16th, 2008, 11:24 PM   #11
Hi Dan. Yes that's right, it's just not so obvious at first. Glad you got it working.
Richard
Old August 17th, 2008, 12:29 PM   #12
Sponsor: JET DV
The marker NUMBERS really don't make any difference. It's the POSITION of the marker that counts.
Edward Troxel is offline   Reply
