Vista 64 and 8.0c and 8.1 problems at DVinfo.net
Old April 4th, 2009, 11:53 PM   #1
I just bought a new computer with Vista 64 bit. I installed 8.0c and 8.1. Neither will recognize any of my previous m2t files, or cineform files!!!
I'm dead in the water. Help.
David Rice is offline   Reply With Quote
Old April 5th, 2009, 01:08 AM   #2
Frustrated
After a number of re-installs of 8.0c and 8.1 they will both now recognize old mpeg files, but neither will recognize Cineform Files. I am also getting a error message about a "COM Surrogate" stopped working?
Old April 5th, 2009, 01:40 AM   #3
Vegas 8.1 will not recognize Cineform. And you need to rename the Cineform.dll in 8.0c to something else to get it to recognize them in Vegas 8.0c.
Intel Core 2 Quad E6600(@3GHz) | Nvidia GeForce 9600 GT/1GB PCI-e x16 DVI |
8GB DDR2-SDRAM | 2 x 1TB S-ATA2/7200rpm/32MB Hard Drives | Vista Ultimate 64
Mark Duckworth is offline   Reply With Quote
Old April 5th, 2009, 07:48 AM   #4
I already renamed the file. 8.1 is still not recognizing cineform files and giving me the error message " Com Surrogate not working"
Old April 5th, 2009, 09:28 AM   #5
8.1 does not work with Cineform .avi files. You can re-wrap the .avi files to .mov using HD Link and those will work with 8.1 .
Old April 5th, 2009, 11:40 AM   #6
Are you using a legally registered copy of the program?
Rick Diaz is offline   Reply With Quote
Old April 5th, 2009, 12:48 PM   #7
License?
I am. I was told over at the cineform forum to forget 8.1, and stay with 8.0c.
Old April 6th, 2009, 10:15 PM   #8
David,
If you are still dealing with COM surrogate issues here are some possible solutions.
Fix for COM Surrogate Has Stopped Working Error in Vista :: the How-To Geek
I had some COM issues with .m2t files and .mpeg files after setting up a dual boot 64 bit Vista system, with Vegas 7.0d and 8.0c and Premier CS4/After Effects CS4. Any time I would explore into my video folders with those type of file extensions either through the editing software or even simply through Vista OS I would get COM surrogate has stopped working errors. I could still grab a file and work with it while the error message was still open but it was a PITA.
The above link I found simply by typing com surrogate has stopped working into yahoo....and then followed the outline for customizing Vista's DEP settings. Has worked perfectly ever since with no errors or problems. I did have to ensure that just about any type of software that runs a chance of accessing a .mpeg/.m2t file was added to the DEP list so I would think that would hold true in your instance as well.
All the best,
James Hooey
James Hooey is offline   Reply With Quote
Old April 7th, 2009, 08:40 AM   #9
The COM surrogate issues have mysteriously disappeared. My big problem right now is that Vista will not allow any software that I have tried to Capture in HD. Vista will not even recognize the Camcorder in Device Manager, if the Camcorder is turned on in the HD out mode. I have tried Capturing HD with Vegas 7, 8.0c and 8.1, cineform Neo Scene, and HD Split. But, DV Captures fine. It's not the Camcorder because my old XP machines captures HD with no problems.
If you do a Internet Search of Vista 64, you will see that their are many HD Capture problems involving many different Camcorders and Softwares. Some are blaming Vista 64, some are blaming the camcorder manufactures, Some are Blaming Vegas, Adobe or who ever. I just wish that someone can find a fix.
Old April 7th, 2009, 09:56 AM   #10
I've been using my HV20 with Vista64 since July and shoot solely in HDV. Have yet to have a problem capturing with my system whether using PowerDirector 7, Vegas Platinum, or both 32- and 64-bit versions of Vegas Pro, which is my primary NLE. HDVSplit does not work on V64, not for me, anyway.
Old April 7th, 2009, 10:12 AM   #11
Rick, In Device Manager where is Vista 64 seeing your HV20? In IEEE 1394 or down in Video & Game Controllers?
Old April 7th, 2009, 11:04 AM   #12
In HDV mode the HV shows up as "Canon HV20" under Sound, Video and Game Controllers in Device Manager. In Vegas Platinum/Pro it shows as this:
http://i3.photobucket.com/albums/y67...turewindow.jpg
Old April 7th, 2009, 08:44 PM   #13
David, I see you have another thread regarding capture issues with Vista 64 as well.....
Anyway, here's my opinion.....
COM surrogate issues don't just go away without some form of intervention....and to further that it now seems to be related to your capture problems....I think the two are intertwined in your instance.
My understanding of Vista's DEP (data execution prevention) as it relates to video is that Vista will generate COM surrogate errors if it cannot appropriately find or work with a particular video codec. Either a codec is missing or corrupted or moved to a location that Vista can no longer logically locate. In particular I would suspect a .mpeg codec seeing as that deals with HDV .m2t files.
It would be my guess in all the tweaking/reinstalls you have done there are either multiple .mpeg codec conflicting with each other or something has been done that has deleted or moved them. If this were the case then one would expect the COM surrogate messages to cease as they no longer have any issues with a unrecognized coded (Vista simply wouldn't be trying to work with the codec if it can't find it). An Vegas would not necessarily be able to capture the HDV footage as it too has lost it's suitable .mpeg codec.
The best advice I could give is to start fresh, both with a clean Vegas install, and even the possibility of a OS install. Then methodically install applications and test at each step to ensure that appropriate video codecs get installed accordingly....(Vegas needs to be registered before working with .mpeg btw). As well if working with multiple versions of Vegas you want to keep tabs on the bundled cineform codec as multiple Vegas installs create multiples of the cfhd.dll that conflict and cause problems. This was a issue when Vegas 8.0 was first released and the workaround has been to rename the multiple cfhd.dll to something else like cfhd.txt.
As a final note I will certainly say that Vista does not from my experience have any particular issues with HDV footage. I've installed a dual boot XP/Vista 64bit setup and have been working with Vegas 7.0d,8.0c,8.1 and all the Adobe Creative Suite software without issue after working out a few niggles like the COM surrogate and cfhd things I have previously mentioned. I can capture from a XHA1 in both OS's and with all the various software without issue.
I would go back to the start and just do step by logical step until it is all up and running.
All the best,
James Hooey
