Vegas Video discussions from 2005 (Q3Q4) - Page 78 at DVinfo.net
Old November 18th, 2005, 10:55 AM   #1156
Sponsor: VASST
Yes that does help. I would uninstall it and reinstall it in the Program Files folder like it wanted to do. Vegas (and all other programs) will find it because it will register itself as a new video codec, not because it’s in a particular directory.
It should still work, but I would re-install it into its own directory just in case you uninstall Vegas at some future point, you don’t mess up 3ivx.
My other instructions still apply as to how to get Vegas to use it for rendering. You have to build a custom AVI rendering template that uses the 3ivx codec.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline
Old November 18th, 2005, 01:20 PM   #1157
Originally Posted by John Rofrano
Faster? No. Think about it: Going from 1080i to 1080i is a straight re-encode. Going to 720p requires a resize, deinterlace, and re-encode. The speed of your PC will determine how much longer 720p takes to render but it will definitely be longer than going straight to 1080i from 1080i source because the computer has to do more calculations to make 1080i into 720p.
~jr
Indeed that make sense, I kinda figure that also but wasn't sure. Thanks!!
Fred Foronda is offline
Old November 18th, 2005, 03:10 PM   #1158
Worked great. Thanks as always.
Jon
Jon Omiatek is offline
Old November 18th, 2005, 06:11 PM   #1159
powerpoint > Vegas ?
How can I get powerpoint presentations into Vegas ...just stills of graphs and stuff like that
Vince
Vince Debart is offline
Old November 18th, 2005, 06:14 PM   #1160
The easiest method is to go to the File/Save As in PowerPoint, and save the slides as jpgs or png files that Vegas can import.
Then in your Vegas prefs, set the "Still Image Length" in your Options>Prefs>Editing dialog, to the length of time you'd like the slides to appear in Vegas.
That's it....just drag em' to the timeline in Vegas in the order you'd like them to appear.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old November 19th, 2005, 04:13 AM   #1161
Vince was asking about stills but I wonder if we could expand it to cover animated Powerpoint presentations.
I have had only limited success using software like CamStudio and Camtasia to capture a full screen presentation containing animated elements. I wonder if anyone else has enjoyed better success with any other tools?
I'm not aware of any tool that can convert a Powerpoint presentation into, for example, an avi. Anyone know of such a beast?
While writing this it occured to me that there may be tools to convert PP into Flash which can then be brought into Vegas. A brief search tells me there are, although the couple I looked at were a little out of my price range.
Any experiences people might like to share?
Ian Stark is offline
Old November 19th, 2005, 06:15 AM   #1162
Sponsor: JET DV
Camtasia (or it's smaller brother "SnagIt") is probably one of the better ways to go in order to get the animations. Here's a tutorial where someone used Camtasia:
http://www.powerpointbackgrounds.com...int-to-dvd.htm
Another option would be to run the computer output through a scan convertor back into Vegas. However, that's a long convoluted process - camtasia's much easier.
If you're only wanting the stills, check out Liam's image convertor:
http://stream.imagebeam.com/tools/po...imageexporter/
Edward Troxel is offline
Old November 19th, 2005, 10:55 AM   #1163
few vegas questions
Hello
I have a few questions about vegas
1. once i have applied an effect to my video is there any way to preview the footage in full screen without rendering out the whole seen first?
2. what settings do i need to choose when starting a new project?
3. i have the FX1 PAL what settings do i need to output to, in order to get the highest quality? final results will be put onto a DVD for viewing on a HD set.
Thanks for the help.
Jim Rog is offline
Old November 19th, 2005, 10:59 AM   #1164
Mainconcept H.264 V2
Hi, does anybody know, how can i integrate the H.264 in Vegas?
I have licensed H.264 V2 encoder, I can converted my output files in this encoder, but i would like to do it in Vegas, like with MPEG2 (or Divx and etc.)- just choose codek and run rendering.... there is also problem, that Vegas does not recognize files in H.264 ...
Tanks, H.W.
Hendy Witanto is offline
Old November 19th, 2005, 11:39 AM   #1165
On2, cleaner, etc. Everybody's entitled to my opinion ;-)
I don't think the On2 codec is better than WMV, but finally it is in a decent ballpark and flash video has come of age. I think the choice of flash video is now reasonable, but you'd probably choose it because of the other things you can do in a flash layout. Best interactivity, best vector animation, best ability to deal with layers, best ability to change screen layouts on the fly.
Cleaner is dead-ended and hasn't received an update in a long time. Apparently Discreet (who bought it from Terran several years ago) is not and will not be putting any resources toward keeping this formerly great application up to date.
Seth Bloombaum is offline
Old November 19th, 2005, 03:41 PM   #1166
Sponsor: JET DV
Sure. Assuming you mean external preview, you can just connect an external device via firewire (through a camera or convertor) and click the 'External preview' button. This will show you your effects UNLESS you've pressed the split screen button just above the preview screen. You also have an option of sending the external preview to a secondary monitor. That's all configurable in the preferences.
Depends on what type of project you're doing. Assuming you're using HD footage (based on the next question), and you're going to an SD DVD, you'll probably want to use one of the widescreen presets. You can also use any appropriate HD preset as well.
There are many answers to this question in the HDV Vegas forum. For example, take a look at this thread:
http://www.dvinfo.net/conf/showthread.php?p=384976
Old November 19th, 2005, 04:05 PM   #1167
Sponsor: JET DV
First of all, are you using Vegas 6.0c?
Old November 19th, 2005, 04:27 PM   #1168
Hello
Thank you very much for the reply.
2 other quick questions
1. is it possible to use the LCD display of the camera to preview the footage in vegas?
2. i have just ran into a problem everything seems to be working ok but when i try to apply a transition it does not work. i have read through the help and still does not work for me. what i do is go to transitions choose the effect i want then drag it onto the timeline but its not going on there nothing happens any ideas? Am I doing it correct by going to transitions choosing the effect then dragging it onto the timeline?
Thank you for any help
Jim Rog is offline
Old November 19th, 2005, 04:39 PM   #1169
You can but I wouldn't recommend it. Low resolution, and doesn't show artifacts that would appear on CRTs.
It also may not overscan.
Is there a fade transition there already? Drag the end of one clip and overlap it onto the other.
Then apply the transition.
Glenn Chan is offline
Old November 19th, 2005, 04:51 PM   #1170
Hi Glenn
Thank you for your help works great now
i am going to order the vegas training dvd i think that’s going to be the best because there is a lot in there to learn and to get the best out of it the training would go along way so i am going to get that and hope i can learn all the things i need to.
Thanks again for the help
Jim Rog is offline
