Vegas Video discussions from 2005 (Q3Q4) - Page 9 at DVinfo.net
Old July 17th, 2005, 10:34 AM   #121
White Balance - How to correct?
I had a crew hired to shoot my son's 1st birthday party. Somehow, they misbalanced the white balance in one of the cameras and a lot of that footage is looking real bad. Is there a way to correct it in post with vegas?
Gustavo Nardelli is offline
Old July 17th, 2005, 12:11 PM   #122
http://www.wideopenwest.com/%7Ewvg/tutorial-menu.htm
Billy has some great tutorials here for correction.
Don
Don Bloom is offline
Old July 17th, 2005, 03:17 PM   #123
I tried the dedicated firewire card and it worked! The controls and advanced capture are working properly. A few dollars well spent. Thanks Gary.
Nature Boy
Phil French is offline
Old July 18th, 2005, 07:10 AM   #124
Keep Vegas, sell Adobe?
I've been a Vegas user since version 4, and I love it. About 6 months ago, I was on a real spending spree, and bought Adobe Video Collection 2.5 Standard.
I installed it, and I never use it. Vegas 6 does everything I want and I actually know how to use it (unlike Adobe Premiere...)
Anyway, is there any compelling reason I'd keep this? Otherwise I'm just going to sell it and buy some software I'll really use. I'd just hate to sell it and later find out there are tools in there you just can't live without.
Chris Davis is offline
Old July 18th, 2005, 08:56 AM   #125
RED Code Chef
Perhaps the audio tools (audition) can do some things that Vegas can't do,
other than that I can't really see any benefits...
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old July 18th, 2005, 09:48 AM   #126
Jubal 28
No reason not to keep After Effects. It will do quite a bit that Vegas can't.
David Jimerson is offline
Old July 18th, 2005, 11:13 AM   #127
Surround sound, vegas or dvd architect?
Forgive me if this has been asked before
So I started out with 5.1 surround sound project in Vegas 6b. Rendered as MPEG2 and imported to DVDA 3b to build menu. When I hit "Make DVD" I have an option to choose the Audio Format and by default Stereo was selected. What should I do? I want my surround sound to stay intact. Do I change it from Stereo to 5.1 surround?
Please help.
AP
Allan Phan is offline
Old July 18th, 2005, 11:53 AM   #128
Sponsor: JET DV
Did you export the 5.1 audio as AC-3 from Vegas? If not, you need to do that and use that file for the audio.
Edward Troxel is offline
Old July 18th, 2005, 12:19 PM   #129
Hmmm... I do like Audition. Maybe I should try learning how to use After Effects and then decide. Perhaps between those two products, it will be worth keeping.
Old July 18th, 2005, 02:15 PM   #130
Chris, I'm in the same exact boat you are!
I have both and bought Adobe Video Collection because I experienced (allegedly) unrepairable rendering issues with Vegas 6.0 (and Sony told me Vegas does not support 64 bit O/S, HA!) Anyway, I solved the render issue and now also have both programs. I have no intention of sending back Adobe because Photoshop CS and After Effects are well worth having.
My two cents worth. Only send it back if you can't feed your pet turtles without the refund.
Interesting, if true. And interesting anyway.
Hugh DiMauro is offline
Old July 18th, 2005, 05:39 PM   #131
If you rendered a dvd compliant mpeg with audio, your 5.1 audio will have been downsampled to 2ch. As Edward said, you need to render the audio to a seperate 5.1ch ac3 file.
While the normal practice is to render an mpeg with no audio, and then render the ac3 to a separate file (unless you also want a 2ch track as well), I just thought I'd mention that to save another lengthy mpeg2 render, you can simply open your project and render the ac3 file, then open DVDA and just replace the audio with the ac3 file - much quicker (provided bitrates, etc are all ok, which they probabably will be).
Kyle Ringin is offline
Old July 18th, 2005, 05:52 PM   #132
Jubal 28
Well, he gets a lengthy MPEG render either way -- either he renders a new, DVD Architect-compliant MPEG from Vegas, or DVDA re-renders the video when it prepares the DVD.
I'd go with Vegas, because for the most part, any time you make a change to the DVD (fix a typo, reorder the menus, etc.), it will have to render the video AGAIN (though, as Ed Troxel pointed out elsewhere, DVDA3 does a little better with this). Render it from Vegas, and you render only once.
Old July 19th, 2005, 11:37 PM   #133
Two tracks of video overlapped.
Hi all,
I'm working on a dance recital video and I have each camera (I used two) on a separate track.
What I've noticed is if the upper track is playing there is a "ghost" of the lower video track that shows in the preview. I've checked to ensure that the top track's opacity is at 100% but there are still faint "ghosts" of the other track visible.
What I've had to do is cut the bottom track so that they only overlap as the dominant track fades out or in.
Is this ghosting effect the "nature of the beast" so to speak or can I do something other than going back through the video and ensuring that there is no overlap between video track one & two?
Thanks for the help.
sincerely,
ian
Ian Slessor is offline
Old July 20th, 2005, 07:13 AM   #134
Sponsor: JET DV
Perhaps you changed the compositing level of the EVENT. You do that by moving the mouse to the top edge of the event, clicking, and dragging down. It's really noticable if you have a fade in/out as the curve will not go all the way to the top of the event. If that's the case, just click on the "line" that appears on the event and drag it back to the top of the event.
Old July 20th, 2005, 08:30 AM   #135
Well, that's embarrassing...
Hi folks & Ed especially,
Well, I'm messing about with the various settings and I focus on the compositing button and go through the various settings and then I notice, quite by accident, that the slider to the left of the compositing button for the event (my top video track) was slightly off of 100%.
D'oh!!!
Thanks Ed for the clues that pointed me to the culprit which was, um, me.
*sigh*
sincerely,
ian
