Original Clip Timecode in Timecode Window? at DVinfo.net
Old December 10th, 2010, 09:04 AM   #1
I know how to get it so that the clip's original timecode will show at the start, middle and end of the event on the timeline (Prefs-Video - show source frame numbers on event thumbnails as - timecode) - but how can I get it so that I can have a more accurate running timecode of each clip, like you can have a timecode window for the timeline? Is this possible?
Jon Brady is offline   Reply With Quote
Old December 10th, 2010, 09:25 AM   #2
Sponsor: JET DV
Drop the timecode effect on the clip in the Project Media. That will show the original timecode from the original clip on the preview screen.
Old December 10th, 2010, 05:34 PM   #3
That just shows the timecode of the clip length rather than the timecode that the camera printed? I'm talking about the TC in-camera.
Old December 10th, 2010, 07:58 PM   #4
If you do what Edward said, then you'll see source time code.
If you have at least Pro 9, run the "Add Timecode to All Media" script and it will do the same thing.
Old December 11th, 2010, 05:07 AM   #5
I can't drag an effect onto project media, cursor turns into a red circle with a line through it.
I'm using both 7 and 9, would ideally like a method for both...
How would I run a script?
Old December 11th, 2010, 07:03 AM   #6
In 7, right click on the file while it's still in the project Media tab, select Media FX and choose Sony Timecode.
In 9, go Tools - Scripting - Add Timecode to All Media.
Old December 11th, 2010, 08:37 AM   #7
Sponsor: JET DV
If I remember correctly, the script goes back much farther than version 9. I was thinking it first appeared in version 5 or 6. In all versions of Vegas Pro, you can get to the scripts by going to Tools - Scripting.
If you just click on a clip in the Project Media, there's a "Media FX..." button in the Project Media toolbar. Or, as Mike said, right-click the clip in the Project Media and choose "Media FX..." When added in the project media, it shows the original SOURCE timecode which is what I thought I said the first time and what I thought you were asking for.
Remember, you have to go back to the Project Media and remove the effect to remove the timecode overlay. If you run the add script, you can run the remove script to remove them.
Old December 11th, 2010, 06:17 PM   #8
Ah brilliant, thanks very much for this!
