Pan/Crop Question at DVinfo.net
Old October 5th, 2005, 03:18 PM   #1
Pan/Crop Question
I know it's probably a simple solution, but I can't quite get it. There's a shot where writing on a paper is just slightly getting cut out at the edges of the tv screen. According to the "safe grid" it should be just inside the tv screen, but when I play the CD on the actual tv, the first and last letter are just slightly outside the frame. How do I pan/crop (or something else) to get it all in frame for the tv? Thank you.
Ruben Pla is offline   Reply With Quote
Old October 5th, 2005, 03:24 PM   #2
Sponsor: JET DV
I would probably use Track Motion to simply make the video slightly smaller so everything would fit. If you use Pan/Crop, you will need to make the Pan/Crop screen BIGGER so that the image will become smaller.
Old October 5th, 2005, 04:20 PM   #3
Thanks, Ed. I'll try it. I've never used Track Motion, but I'll go read up on it and, if I can't figure it out, I'll get back to you.
Ruben
Old October 5th, 2005, 04:46 PM   #4
I tried, but I can't get it. How do I do it? I need to make the last letter on either side a little more inside the safe area.
Old October 5th, 2005, 05:00 PM   #5
I went back and tried the making the pan/crop screen bigger, and that does get all the letters in the safe zone, but now there are black bars all around the frame.
Old October 5th, 2005, 09:25 PM   #6
Sponsor: JET DV
You could add a generated media of the proper color on a track below that track to make it a different color. However, by making it smaller, you will have an edge of some color (black by default)
Old October 5th, 2005, 11:57 PM   #7
Is there a way to reduce the frame, so it's all within the safe zone, crop the black borders out, and then enlarge that frame it so that it fills the whole screen? Can that be done? It seems like it should be.
Old October 6th, 2005, 07:46 AM   #8
Sponsor: JET DV
The only way to "crop out the black borders" is to make them "not black." Put a generated media of the desired color on a track below that event.
Old October 6th, 2005, 10:10 AM   #9
Sponsor: VASST
One trick is to duplicate the media on the track below and add a Gaussian Blur. Now when you crop the upper track to get the text to fit within the safe area, instead of black bars you will have the same color as the original background only blurred. Sometimes it’s not even that noticeable.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply With Quote
Old October 6th, 2005, 04:56 PM   #10
Ok, thanks. I'll try that.
