DVD Architect Sudio? How do you do a menu? at DVinfo.net
Old January 15th, 2007, 08:23 AM   #1
Ok I have my file saved in as a MPG2 from Vegas and then I go and create a Single DVD and pull the file in and I cant figure out how in the hell to do it.
Im lost any one have any simple directions?
Tony Jucin is offline   Reply With Quote
Old January 15th, 2007, 09:10 AM   #2
Sponsor: JET DV
Take a look at Vol 4 #1 of my newsletters.
Old January 15th, 2007, 10:05 AM   #3
The manual and even the built-in Help File explains it all very clearly.
Of course, if you got a P2P "torrent special", you're on your own....
Tim OBrien is offline   Reply With Quote
Old January 15th, 2007, 10:42 AM   #4
"Saved?" or "Rendered?"
If you've rendered it, then in DVD Architect, look for the rendered file via the DVD A explorer. Drag it to the blue worksurface, and effectively, you're done.
There are lots of books and DVDs that may help you if you're not grasping the manual.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old January 15th, 2007, 03:01 PM   #5
Where would I be with out you or Spotted Eagle :)
Ok It says the first steps is to make the chapters, do you do this in vegas or architect? Because basically what I was trying to do is take the complete rendered file from vegas that is a mpg2 format and then I added chapters and couldnt figure out what to do from there. But I notice in the news letter it says once you add the chapters and render it will automatically detect them?
Old January 15th, 2007, 03:36 PM   #6
Sponsor: JET DV
Regular markers on the timeline in Vegas will be interpreted as chapters in DVD Architect as long as you check the render option to include the markers.
You can also add the chapter points in DVD Architect.
Edward Troxel is offline   Reply
