Adobe Premiere discussions from 2002 - Page 27 at DVinfo.net
Adobe Creative Suite
Old December 20th, 2002, 11:13 PM   #391
"I have rendered files larger then 18 minutes before, it just isn't working now."
I suspect that the 18-minutes+ files you rendered before were (a) rendered at a lower resolution; or (b) rendered to a codec with higher compression (e.g., MPEG or DIVX). It's the file size, not the clip length, that causes the limitation.
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline
Old December 20th, 2002, 11:40 PM   #392
Thats it. It must be the 4 gig limit because the file was 3.99 gigs. Thanks you guys. I guess I am going to have to work around it some how. I'll go buy myself Windows XP after Christmas. Thanks, you guys have come through for me once again!
Scott Silverman
Shining Star Digital Video Productions
Bay Area, CA
Scott Silverman is offline
Old December 27th, 2002, 02:14 PM   #393
Michael Linder
Posts: n/a
I'm using Premiere 6.5 which has an excellent new titling system. It comes with more than 40 lower third templates, most of which are pretty cheesy, but they're good starting points and you can save your customizations. You can also insert logos and see your video behind the lower third or title as you're composing. Premiere 6.5 also does rolls and crawls painlessly, too. Bottom line, you won't ever have to go back into AfterEffects to create lower thirds.
--Mike
Old December 27th, 2002, 05:55 PM   #394
Yeah, Premiere has good titling tools as of 6 and 6.5. The only time you'll need to use After Effects would be for complex titles that use motion graphics etc.. But for simple, clean, professional titles, Premiere should be all you need.
alextaylor.org
Alex Taylor is offline
Old December 27th, 2002, 06:09 PM   #395
Still & Animated Lower 3rds
The bundled Inscriber CG is a great CG as stated in earlier posts. There is a company called Digital Juice that offers some INCREDIBLE still & animated full screen and lower thirds already pre-produced ready dropping into the timeline. You can sample all of their graphics at the link below.
www.digitaljuice.com
James Emory is offline
Old December 29th, 2002, 06:38 PM   #396
RED Code Chef
If you convert all your partitions to NTFS (either with Win2k
professional that I would recommend or XP) your problem should
be gone!
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old December 29th, 2002, 07:09 PM   #397
Yeah, I plan to upgrade to WinXP after New Years when I get back home. I am on vacation in NJ right now with my new GL2. Lots of fun!
Thanks you all for your help!
Scott Silverman
Bay Area, CA
Old December 30th, 2002, 01:54 PM   #398
premiere freeze frame
I can't find this answer in any of my manuals.
I believe there's a keyboard shortcut that allows you to capture the video at the markerpoint on the timeline as a freeze frame. Does anyone know the shortcut?
fargogogo is offline
Old December 30th, 2002, 03:23 PM   #399
If what you want is a single frame saved as an image file, use Ctl+Shift+M
Ed Frazier
Ed Frazier is offline
Old December 31st, 2002, 07:22 AM   #400
Thank you!
