Adobe Premiere discussions from 2003 - Page 13 at DVinfo.net
Adobe Creative Suite
Old April 30th, 2003, 05:29 AM   #181
Ron,
I haven't found a way to correct the still durations en-masse once they are on the timeline. I did pick up what I thought was a nice technique from one of the third party books on Premier.
You can set the default still duration under Edit-Prefs->General and Still Image. Set this to how long you want, Open the storyboard and right-click and import file adding all of your still shots to the storyboard. Arrange as necessary, then click Automate-to-Timeline button on the bottom of the Storyboard window. It opens a dialog allowing you to spec the position on the timeline and to turn on or off the use of the default transition.
Setting the default transition can be found quickly under the help file.
I found it to be a quick shortcut for setting up still slideshows.
I've not used the MPEG-1 output from Premier so I can't comment there. I typically Export to MPEG-2 with the DVD NTSC profile and then let the authoring/burning program re-encode to VCD MPEG-1.
Perhaps someone else can answer that question for you.
Rob Talley is offline
Old April 30th, 2003, 10:04 PM   #182
Hey buddy I had the same problem. Go to your playback settings and uncheck the box that says playback in camera. That's what solved it for me.
Vlog On!
http://youtube.com/clintus
Clint Comer is offline
Old May 1st, 2003, 05:41 AM   #183
You should always turn the camera on before loading up premiere. This way premiere and windows knows that there is a new device. Have you selected your camera from the device control list in premiere (Or nearest one)?
Cheers,
Ed Smith
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline
Old May 1st, 2003, 12:21 PM   #184
RED Code Chef
Any chance Premiere is de-interlacing your picture? In what format
and resolution is Premiere loading the image?
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old May 2nd, 2003, 06:13 AM   #185
Premiere Capture Problem
There's nothing wrong with upgrading but before you do, if you haven't installed the free upgrade to 6.02 it's worth a try:
http://www.adobe.com/support/downloa...atform=Windows
David Hurdon
David Hurdon is offline
Old May 3rd, 2003, 11:07 AM   #186
Thank you for the suggestions.
The stills are from a digital camera and there are more pixels in the stills than in mini DV. I am using Premiere to import the files with defaut settings except for the odd shot that was framed vertically and then I use "Maintain Aspect Ratio" to keep the right perspective.
How would I know whether Premiere were de-interlacing the images?
RJ
Ron Johnson
Portland, OR
Ron Johnson is offline
Old May 4th, 2003, 12:24 PM   #187
Premiere not recognizing 1394 card
A few days ago I took out my firewire card and put it in my new computer. It turns out the IDE controller on my new computer was faulty (due to bad shipping) so I'm waiting on the insurance claim for it. In the meantime, I needed to put my firewire card back in my old computer. I put it back in and booted it up, and Windows XP detected it just like it should.
I plugged in my camera and turned it on, and loaded Premiere. Premiere would not recognize that I had a 1394 card or a camera hooked up to it.
I thought it might be because XP was using the Texas Instruments drivers for the card, so I ran UnTI and now it's listed in the Device Manager as OHCI Compliant IEEE 1394 Host Controller. I thought that would do the trick so I loaded Premiere again. Still the same thing; I go into Device Control and it just says that the device is offline, when it's really plugged in, turned on and ready to go.
What would this posisbly be? My card worked fine before I took it out, no problems. It's a Pyro BasicDV.
Windows XP Home
Pyro BasicDV firewire card
Adobe Premiere 6.5
Canon ZR20 camcorder
The card is sharing IRQ 5 with the USB controller and my sound card. Both my network cards are on IRQ 11.
alextaylor.org
Alex Taylor is offline
Old May 4th, 2003, 02:48 PM   #188
Alex did you try re-installing Premiere *after* re-installing the drivers. I have found that Premiere is VERY picky about this. Just a shot in the dark.
DVX100A/AT4071a/Vegas/After Effects
Dual 2GHz Xeon PC
Stuart Kupinsky is offline
Old May 4th, 2003, 03:07 PM   #189
RED Code Chef
Premiere only de-interlaces it when you tell it to. When you are
exporting you can also select de-interlacing (this might be on
by default perhaps?)
Old May 4th, 2003, 03:14 PM   #190
I thought about that, so first I tried going into Windows Movie Maker and seeing if it worked there. It didn't. But do you think re-installing Premiere would help regardless?
alextaylor.org
Old May 4th, 2003, 05:00 PM   #191
If you're out of choices it's worth a shot. After trying all obvious permutations I usually uninstall everything, restart the PC, and then reinstall.
Also, Premiere used to randomly unrecognize my DV500 card. I would restart the PC and voila. [Vegas works everytime in comparison]
Sorry you're having the problem.
Dual 2GHz Xeon PC
Old May 4th, 2003, 05:57 PM   #192
I guess I'll give that a shot then, thanks for your help! :)
All these firewire incompatibilities seem like the thing we'll look back on in 5 years and say, "Wow, I can't believe had to do that!"
alextaylor.org
Old May 5th, 2003, 10:42 PM   #193
Sound tweaking in Premiere 6.0
I've found that in the final stages of sound editing when I want to do really small changes in volume or other things, that using the rubber bands on the timeline are very cumbersome and really unusable for small tweaks.
I've attempted using the sound editing window, but for some reason I can't get the audio sliders to write properly to the timeline. (i.e. set the audio slider to a dB that I want that audio track set at, click the write button, and it simply follows the rubber band settings)
Anything stupid I'm doing here?
Shane
Shane Duff is offline
Old May 6th, 2003, 05:17 AM   #194
Capt. Quirk
Try right clicking on the clip you want to adjust, then select "adjust audio properties", and "adjust gain". It works better than the rubber bands for adjusting the volume. The rubber bands are for fades, and dropping the volume for a voice over to be inserted.
K. Forman is offline
Old May 6th, 2003, 06:21 PM   #195
That's a good trick, any others up anyones sleeve?
