Adobe Premiere discussions from 2003 - Page 31 at DVinfo.net
Adobe Creative Suite
Old August 6th, 2003, 09:13 AM   #451
Try recapturing like 10 minutes of the video and see what happens.
BJ Thomas is offline
Old August 6th, 2003, 09:58 AM   #452
I am not sure if freeing or defragging will do. Some NLEs get a little fussy about defragging in the middle of a project. Rendering might help prevent that.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline
Old August 6th, 2003, 02:05 PM   #453
I tried to recapture 10mins and for some reason the machine fell over - however I do not believe thats the issue. And freed up some space on the HD.
I am running a DV500+ capture card and so thought OK lets see whether they will play in DV tools. And blow and behold they all played correctly in there all saying the correct size - not a problem.
So I created a Premiere storyboard in DV tools of what I had created. Closed DV tools and opened Premiere, imported the storyboard and still Premiere thinks they are only a couple of minutes each - Man this is getting annoying.
I also tried un-installing and re-installing Premiere but that did not work.
Anything else?
Cheers again,
Ed
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline
Old August 6th, 2003, 02:21 PM   #454
Here is a really wierd possibillity...if you are using a pc.. I don't think it will be the answer. but worth a try. sometimes windows gets confused as to the size of the hard drive as reported by the hard drive to the program.
Try running scandisk and see if it says that windows is reporting the wrong size for the drive. if it is, then use the option to repair that error. I have had this happen on a few machines when I know that there is enough room but a program says there is not... Do not let scandisk repair the errors automatically, otherwise you will never know what the error was, if there was one...
Roy
Roy Roberts is offline
Old August 6th, 2003, 07:49 PM   #455
"faster" NLE software than Adobe Premiere 6.x?
when you preview something on premiere it seems to take forever even for a small 5MB file. the workflow just seems to hectic. i've played around with it but haven't had a chance to edit an entire 30min-40min short. but just from playing around with 5MB file Prem 6.x is just so slow. i hope Prem "Pro" is truly re-written from scratch =). i've used apple's "Final Cut Pro" when you drag clips around, manipulate them, preview, etc. it just seems so much faster. 2bad i can't get that for the PC. what's the 'fastest' NLE software on PC?
bow wow wow
Yi Fong Yu is offline
Old August 6th, 2003, 08:11 PM   #456
I can't offer a whole lotta insight, but I will say that I recently tried Vegas 4, and I'm VERY impressed with it over Premiere. Specifically, the workflow. It’ll take some getting used to... but I'm going 100% Vegas.
Steve Withers is offline
Old August 7th, 2003, 03:16 AM   #457
Download the Scenalyser capture program (there is a demo version at www.Scenalyser.com) and see if you can view the entire clip. Although this will not solve your problem I guess it will indicate if there is something wrong with the capture and the saving of the files to the disk.
Hans van Turnhout is offline
Old August 7th, 2003, 08:52 AM   #458
Scrolling credits in Premiere
whats the easiest way to make scrolling credits in premiere? i can' figure this one out..
thanks,
ryan
Ryan McCrary is offline
Old August 7th, 2003, 09:19 AM   #459
Use the title designer File> New> Title.
Depending on what version you have will depend on how you go about creating them in Title designer.
V6 or V6.5?
All the best,
Ed
Ed Smith
Hampshire, UK
Ed Smith is offline
Old August 7th, 2003, 09:21 AM   #460
Hans thanks for the suggestion,
I have done the same sort of thing you are talking about but used DV Tools - created by Pinnacle and comes with the DV500+ capture card. They all worked in that program!!!
Ed
Ed Smith
Hampshire, UK
Ed Smith is offline
Old August 7th, 2003, 09:37 AM   #461
i have 6.0
so i make the title.. use the rolling title tool.. and thenwhen i put it in.. it'll work out the motion?
thanks..
Old August 7th, 2003, 09:44 AM   #462
Capt. Quirk
I have never used the scrolling tools in Premiere, but have had good results using individual cards, and use the motion settings. I start with the card at the bottom of the screen, and finish with it at the top. Then the next one, and so on. It works fine, and I have found it easier.
K. Forman is offline
Old August 7th, 2003, 10:29 AM   #463
No - You will have to right click on your text in the rolling box and then I think its rolling options and possibly there you type in the duration of the credits.
I have not used V6 for a long time 6.5 title designer is completely different
All the best,
Ed
Ed Smith
Hampshire, UK
Ed Smith is offline
Old August 7th, 2003, 01:40 PM   #464
i got it worked out.. thanks everyone..
Old August 8th, 2003, 10:07 AM   #465
I also use the DV500 and Premiere. I really can offer no ideas as to why this happened, but I think I CAN offer a solution to let you use that captured footage.
If the full clips open in Windows Media Player, They will probably open just fine in Quicktime Player as well. You will need Quicktime Player Pro ($30 license from Apple) in order to export.
Open the smallest of the clips, verify that it opens properly, then export from Quicktime Pro as an Quicktime DV codec movie. Make certain that your field and audio settings are identical to your original clip. You might also try breaking up the clip so that no individual file is over 2 (or is it 1?)GB (I've forgotten all the GB limitations with NT,2000, NTFS, Maxtor device drivers, Premiere presets - oh, my head hurts!). Verify that Premiere will now recognize the file using Quicktime DV project presets. You can edit as normal, but maybe without the DV500 live monitor preview.
I'm pretty sure that QT Pro will not re-render the DV data, but will just file-copy it, changing the Pinnacle.avi wrapper to a QT .mov wrapper for the same DV data. That way, it should be a relatively quick conversion. You might even be able to use QT Pro to then convert the files BACK to Pinnacle .avi's. Only problem here is you will have to free room on your HD in order to process the 9 and 12GB monster files.
Scott Anderson is offline
