Extensive forum search of iRiver info. = no answer. at DVinfo.net
All Things Audio
Old January 8th, 2008, 10:40 PM   #1
I'm using iRivers with the Line-in /Ext.Mic input. I've discovered something very stange and it actually looks like a contradiction in the hardware instruction manual.
____________________________________________
(this first part is very clear)
iFP-700 series Manual, page 5-23 states this:
Line-In/Ext. Mic
You can select external microphone or
line-in when recording.
Line-in: To record through line in
Ext. Mic: To record through an external microphone
______________________________________________
(it's the NOTE below, found at the bottom of the same manual page, that is very hard to understand) it seems to be a contradiction to the above.....
NOTE: -To record from an external microphone, chose the LINE-IN recording mode
- The recording quality level will be set to the values chosen for the LINE-IN recording.
Golly, if you could help explain this to me, it would be very much appreciated.
regards, Tom B.
Tom Blizzard is offline   Reply With Quote
Old January 8th, 2008, 11:03 PM   #2
Having made a few recordings with my i890 (?), I believe the translation goes something like this: "Our mic preamp is really horrible. Don't use it. If you use your own preamp, it will sound a lot better."
I know some people use them for weddings, but I haven't had great luck with it.
Andy Tejral
Railroad Videographer
Andy Tejral is offline   Reply With Quote
Old January 9th, 2008, 08:00 AM   #3
Wow, thanks Andy.... I didn't even think about that.
First time I've read that type of experience with the iRiver. Golly, I didn't think you needed a preamp using the Giant Squid mic.
