extreme birdsong; last push on project - Page 2 at DVinfo.net
All Things Audio
Old September 16th, 2015, 05:30 AM   #16
Re: extreme birdsong; last push on project
I'm definitely interested!
Really enjoying being able to "chunk" larger groups of audio and then go in for fine-tuning later. My earlier method looks pretty neurotic in retrospect. :)
Adjul Gardner is offline   Reply With Quote
Old September 16th, 2015, 07:04 AM   #17
Old Boot
Yeah, well, . . . I'm not happy with tweetie-pie - has become a rusty bike chain . . . . I also removed some more White Noise
http://www.dvinfo.net/forum/attachme...1&d=1442409094
Of course, as I started cleaning-up I came across other artifacts.
I also added some SFx - iZo Ozone5 "Dramatic Width and Open Up Mid-Side" to a Brush-ed Selection - neat! Gonna use that again.
Grazie
Old September 19th, 2015, 05:05 AM   #18
Equal Opportunity Offender
I've just listened to the original audio file.
Honestly, just tell them that the audio is terrible and to go back and do a re-shoot. If they can't then it's their problem - otherwise we're effectively subsidising their cheap sense of reality.
Andrew
Old September 19th, 2015, 01:38 PM   #19
Andrew...lol, if i had my time machine, I would go back in time and ream out the camera man (it was filmed 13 years ago). But also, as someone that has done a 1-man-shoot-on-a-budget for near-impossible documentary-filming situations, I can empathize. His poor work inspired my low-budget multi-microphone vector approach to mic'ing large groups.
The good news is, I learned a lot. About pop and crackles, clicks, how to remove lots of coughs and sniffs (the camera man not only laughed a lot, but sniffed even more) and those birds...
Graham: I found that the birds are best treated with RX4s attenuation from .9 -> 2.0. The solo ones can be totally removed, where the long stretches you worked on can be nicely blended into the voice...better than your bike chain at least ! :P
I ended up using a simple technique:
x26 gain on every clip in the film
apply EBU loudness over the whole clip
apply decrackle over the whole clip
Low and high cuts, 90db and a 10-14k db fade-away
From there I went in and manually removed any further clicks, coughs, sniffs, and birds. With RX4s attenuation, partials-spectral-repair-tool, declicker and occasionally just de-gaining. For hums I don't know how to identify and nail exact frequencies as well with RX4 (it tends to want to take out multi-bands) so I used Audacity to seek out hums and removed those to a greater or lesser extent.
Here's my final cut of the horrendous clip in question:
http://www.teachingdrum.org/adjul/showntell.wav
thanks for all the help...about a week away from finishing this documentary I've been working on for two years :)
Old September 21st, 2015, 12:42 AM   #20
Old Boot
You're welcome.
As to the HUM remover, I've found that the multiple harmonics can and do work very well; I can also de-group the harmonics; I also use the Spectrum Analyzer to nail a particular Harmo:http://www.dvinfo.net/forum/attachme...1&d=1442818399
I like your results and still think that RX is just plain VooDoo! - Oh, that's IT Engineer Terminology.
Grazie
Old September 21st, 2015, 04:27 AM   #21
Izotope RX is powered by magical electronic smoke. :-D
Andrew
Old September 21st, 2015, 05:07 AM   #22
Graham - thanks for pointing out the analyzer and the harmonics...simplified my workflow
Old September 21st, 2015, 07:55 AM   #23
While you're at it...Graham, could you tell me if there's a key-command in RX4 that stops the playback at the last place the live-play ended at? For me, spacebar returns to the last place I clicked the cursor, and enter starts at the start of the sample.
Old September 22nd, 2015, 12:57 AM   #24
Old Boot
The RX solution/way is not intuitive. At the moment you/we have SPACEBAR for PLAY, that plays and then RETURNS to the same place. In RX we need to use a "TOGGLE" command to stop this happening, and that is Ctrl+R.
The SPACE Bar plays and returns, and CTRL+R stops this Return happening. Now, when we WANT to revert to the PLAY from start position to play again, we need to, again, press Ctrl+R. I think this is clunky and unnecessary User control.
Grazie
Graham Bernard is offline   Reply
