What causes these cut outs?
Can anyone identify what caused these cut outs?
Equal Opportunity Offender
Re: What causes these cut outs?
Gosh, that could be so many things. I was first thinking it might involve a cable but it's on a regular pattern.
Can you describe the setup for the audio/video recording? Also, we could do with a much longer sample. Andrew |
+1^, Agree that it sounds most like a cable/connector issue, with the regular interval driven by a fairly uniform motion that induces the cable/connector motion; e.g., walking, or rocking chair.
Is it audio only or was there associated video that might provide additional insight into the situation in which it was recorded?
dpalomaki@dspalomaki.com |
Sounds like a cable/connection issue..though RF interference is a possibility if a wireless mic is being used. Without more information, it's a wild guess..
As Andrew stated, "describe the setup for the audio/video recording?" |
#5 |
It was a wireless transmitter/receiver. Receiver was connected to MixPre-3. It was a Sony dual UHF system. I don't remember the model. The person was walking.
#6 |
Is the squelch turned up too high - it's the RF dropping below the cut-off point.
#7 |
Here is a longer sample
#8 |
The cut-out & cut-in wave forms strike me as being too varied and loud to be squelch driven. It looks very much like something driven by a loose or failing 3.5 mm phone jack/plug in the chain. Possibly on the transmitter as well as on the receiver side.
Is there any point where the problem stops or lessens, and does that correspond to a change in the walking pace? (In the longer sample the we see the problem for about 30 seconds, it clears for 40 then returns.) Was the recording done on the PreMix-3, or was it used as a mixer to feed a camcorder or other recording device device? Also I would not expect squelch issues if the transmitter and receiver are within a reasonable distance of each other; 30 feet no, but 300 feet yes, unless it is a unusual venue with lots of walls and extensive metal in close proximity to the transmitter and or receiver. (Or possible nearby transmitters on frequencies close to those used by the wireless system.)
#9 | |
#10 |
I think it's definitely a flaky cable or a loose connection, and it's not going to be fixable.
Don't bother waiting for the video files to arrive. Someone will have to record the interview again, and get a rap on the knuckles for not monitoring the audio while the interview was in progress the first time. Andrew |
#11 |
Could also be handling noise when clothing rubs up against the mic. You should always be wearing headphones monitoring the audio so you can address the problem at the first sign of trouble. If lav mic placement isn't right or the subject knocks the mic off is common lav problem. Like other suggested a faulty cable or connection is another common problem. As equipment ages the risk of a bad connection/cable goes up. It's also not a bad idea to invest in an audio record with lav as a backup. Wireless can be unreliable especially if you're renting or borrowing someone else's equipment. One of the first lessons you learn with live event work you live and die with the equipment you use there are no second takes. If it's an important event and the audio is messed up you'll either need to refund the client and they might never hire you again. So own your own high quality equipment, have intimate knowledge and experience with it, and have backup or redundant audio source.
#12 |
Thank you everyone. This was just a test. We were monitoring the audio. We knew there was an issue. I'm just trying to identify what caused it.
#13 |
Gosh Kathy, thought you had a real serious issue here.
Try wiggling the cable to cause the issue to happen 'on demand'. Andrew |
#14 |
#15 |
Sorry Andrew and Pete that I didn't say that. I like to do tests before I do the real thing.
