#151 |
Azden 400UDR vs. 500UDR???
Can anyone tell me what the difference is between these two receivers? I have a line on a good used 400 but I can afford a new 500 if need be.
#152 |
I use 2 of the 500UDR units and love them. I really don't know the difference between the 400 and the 500 but I'm guessing it has to be very very minor. Edward T. uses the 400 series I believe and he loves his, so whatever the differences they gotta be small.
Don |
#153 |
What's up with SoundDevices recorders?
Anybody know? I had thought they were supposed to have brought the 744T and 722 hard disk recorders to market by now. I wonder if all these inexpensive MP3 recorders out there have made them rethink the market.
#154 |
Just found the answer to my own question. Now they're talking Q1 2004. They've apparently made a major redesign to the system.
#155 |
Shure VP88
Has anyone had any expirience with this mic?
#156 |
Wireless Mic
I'm Using AZDEN 500UDR reciver. My question is:
Can I use more then one TRANSMITTER? right now i only use AZDEN 41BT bodypack transmitter. |
#157 |
There are 2 ways to use more than 1 transmitter, but ones mot the best.
1)you COULD have the little screwdriver in your hand and make the switch on the reciever when you need the 2nd transmitter to rbe received but I really don't suggest that. It's far too easy to miss the frequency, miss the timing or have some other disaster happen, so that brings us to number 2) get a 2nd receiver and if need be a mixer or something like the Studio1 BP XLR aduio adapter. Cost a little more but well worth the peace of mind. BTW, I forgot my 2nd receiver 1 time and tried method 1, needless to say I haven't forgotten my 2nd receiver since. Don |
#158 |
mics for no budget video feature
We're going to shoot a no-budget film in a cabin next month--and I'm trying to get the most reasonable sound I can for a small amount of money.
The camera is an HD-1, which has great picture but supposedly lousy audio inputs--DAT recorders are out of my price range but a friend of ours is donating a mini-disc recorder, which according to some sources is a reasonable second choice. This leaves the shotgun. I looked on B&H where they have an AT815b Line/Gradient Shotgun Condenser Microphone on sale for 279.00 (reg. 399). In addition they have a used At815a condenser microphone for sale for 199. Does anyone know if this is basically the same model? In your opinions, would either of these models provide good enough sound for a project that, in the best possible fantasy scenario would be shown in festival and commercial theatres? Thanks for any advice:) |
#159 |
Hawaiian Shirt Mogul
why not rent a mic ?
for the miniDisc i would rent a XLR box for it - much easier to set volume levels. all XLR cables plug into box then mini stereo cable from box to miniDisc .... also use FILM slate at heads of every shot ..if over 5 min take i would also tail slate ... the 815 is a long shotgun = works good outdoors but so so indoors - forget using in a bathroom ... so depending on your project ? i use short shotgun 90% of the time indoors/outdoors guide on AT mic's http://www.equipmentemporium.com/atmics.htm intro to shotgun mic's http://www.equipmentemporium.com/selectin.htm using boom intro http://www.equipmentemporium.com/introto.htm general sound for DV http://www.equipmentemporium.com/audiohi8.htm |
#160 |
audio delay
I just "discovered" something which may be completely obvious to many of you, but might also be helpful to others that are less experienced (like me! ;-). I've just started editing a lot of performance video that I shot with my PDX-10. For audio channel 1 I used a feed from the house board which consisted of mikes on the proscenium and orchestra pit. I used the on-camera mono microphone on channel 2.
Now since I was shooting at the rear of the house, about 100 feet from the stage, there is a very noticeable delay between the audio on channels 1 and 2, caused by the time it took the sound to travel over 100 feet. It sounds a little disconcerting, and I was wondering if I should even use channel 2 in the mix or just go with the mono audio from channel 1. Then it occured to me that all I needed to do to get the two channels in sync was to delay the audio on channel 2. IIRC, sound travels around 750 mph and audio people like to round that off to about 1 millisecond per foot. Each video frame is about 33 milliseconds, so if you do the math it works out to around 3 frames offset between my audio tracks at a 100 foot distance. So in FCP I shifted the video track and the audio track 1 forward by 3 frames and voila... they were in sync. After a little fiddling I actually decided I liked the way it sounded better with only a 2 frame offset. I blended the two channels together in different proportions and ended up with something that sounded pretty good. Anyway, just thought this might be helpful to someone else in the same situation where each audio channel is fed from mikes that are at different distances from the performers. |
#161 |
Good observation. It would be better to go with a pure delay (no feedback) effect that would allow a higher delay resolution. The effect of adding two audio signals when one is delayed has both a significant transient and steady-state response. Above a certain amount of roughly 20 mS, the two signal are perceived as echos. This is the transient response. Below that amount, usually only the coloration is heard. For any delay amount, there will be a steady state coloration caused by a series of uniformly spaced notches in the frequency response. The longer the delay, the lower the spacing of the notches. For a one sample delay, the effect is a mild (single zero, -6dB/octave attenuation) low pass filter. It's important to listen to both sharp sounds and steady state sounds, in addition to comparing the stereo field. Varying the delay amount will trade off one echo perception, coloration, stereo field. This may help explain why you preferred the sound of two frames even though three was closer to your physical setup.
#162 |
DM-50 question
I just got the DM-50 mic for my GL2 camcorder. I know the windsock is appropriate when I'm outside. Should I use it as a manner of course when videotaping indoors as well? Specifically middle school basketball and choir concerts?
#163 |
LAV. Mic's
I need some advice on a good Lav Mic setup. I was considering Senheisser (excuse my spelling but you know what I mean), but a vidoegrapher friend of mine told me to check out the Audio Technica?
#164 |
Where are you going to use them? General use or movies or?
Tram, Sony, AT, Senn, and others make good ones. But they all apply better in some situations than others.
Mike Rehmus Hey, I can see the carrot at the end of the tunnel! |
#165 |
newbie question
ive noticed a lot of camcorders have either 12 bit 4channel or 16 bit 2 channel. my question is this is it possible on some camcorders to use the 12 bit mode and have 2 stereo mics? either by having one as the built in mic and one external plugged into the mic socket or 2 external.
| Thread Tools | Search this Thread |
