MA300 XLR microphone adapter - Page 3 at DVinfo.net
Old February 20th, 2003, 12:24 AM   #31
Warden
Sound Devices makes the MM-1, the finest pre-amp on the market in my opinion. It's pricey, but you said the best.
Jeff Donald
Carpe Diem
Old February 20th, 2003, 12:26 AM   #32
Retired DV Info Net Almunus
There's a link to the Rolls in one of my last posts on that thread.
The MM-1 can be found at Sound Devices' site.
Old February 23rd, 2003, 03:28 PM   #33
Thanks for the links guys. Do these preamps offer XLR connections?
Aaron Rosen is offline   Reply With Quote
Old April 11th, 2003, 03:55 PM   #34
MA-300 Question...
Question to anyone who owns the MA-300 microphone adapter:
What are the pros & cons of using the BNC video output of the MA-300 to patch into an external monitor, versus the RCA cables that can be patched directly from the back of the GL2 with the RCA inputs that come with the camera. Why route it through the MA-300 at all?
Just curious...
Noka Aldoroty is offline   Reply With Quote
Old April 11th, 2003, 11:21 PM   #35
You said it!
I can't believe Canon did this. How hard would it have been to include a video return with those hardwired audio returns to the camera? There is no technical advantage except that you now don't need a BNC adapter to use a pro monitor but you DO now need a video patch cord to use that BNC connector from the 300 to the camera. Who approves these things before they hit production? Unbelievable!!
James Emory is offline   Reply With Quote
Old April 12th, 2003, 01:21 AM   #36
Oh, and one more thing...
I have one more question concerning the MA-300. How can I get it to input audio in stereo? I have only one shotgot microphone, patched into one of two XLR inputs on the MA-300. The two XLR inputs are labeled Left and Right, but with one microphone source, how do I get sound into both the left and right channels? What's the best solution?
Old April 12th, 2003, 02:00 AM   #37
XLR Y Adapter
All you need to accomplish your goal is to get an XLR Y adapter. B&H or any pro audio store should carry these. I got mine from B&H who resells the Comprehensive brand. They also carry the general brand. I think they're all the same to tell you the truth. Look for the Neutrik name on the shells for best quality assurance.
Old April 12th, 2003, 02:11 AM   #38
Old Boot
Errmm . . . I think I got one of these cables that came with my XM2 kit. - I've asked several people about the BNC, and they too were a bit bemused with the "loop" back to do this. Another wire to loose eh?
Old April 12th, 2003, 02:19 AM   #39
Old Boot
"What's the best solution?"
"...how do I get sound into both the left and right channels? " - Well there is an argument that you could do this in post with any more than average competant NLE s/w. I have used SoFo's Video Factory [$45-ish USD] gives the option to "pan" the audio to L>R or R>L AND find a balance on that split mono - yeah? Did this with my mono analogue Panny Cammy - works like a dream.
I say there is an argument for doing this in post because you could leave the "other" XLR channel for "other" audio input - wireless, ambient non-shotgun mic - yeah? Doing stuff in post -including colour correction - means you have far more creative control of the final production. If it aint in the can you can't create it in post.
Hey what do I know! - I'm still learning.
Grazie - Sorry Chris, can't get away from my nickname - yeah?
Old April 12th, 2003, 02:32 AM   #40
Mixing Left and Right
I'll be doing most of my editing work in Final Cut Pro, and being able to drag shots into the timeline with dialogue already mixed evenly between the left and right channels will save me having to manually add the dialogue into the second channel for every single shot. If dialogue is recorded evenly in the left and right channel, I can pan the audio left and right within FCP easily enough if it is necessary. So, am I hearing correctly that the XLR Y splitter is my best bet for this?
Old April 12th, 2003, 04:53 AM   #41
Old Boot
I haven't used FCP. I can't comment, other than doing a test to confirm what's best for you - either way. Recording on both channels? Does it produce better quality? Again I don't know - others can chip in here. - Like I said, I recorded mono and panned to get a pseudo stereo effect - this was in SoFO Video Factory.
Old April 12th, 2003, 11:59 AM   #42
Dual audio
Why would you want to create more work for yourself later when you could spend 20.00 ONE time and get the result you are looking for on site every time?
Old April 13th, 2003, 11:57 AM   #43
Contributor
MA-300 Question
Can somebody tell me, can a MA-300 be used with a GL-1?
Thanks.
Jim Treganza is offline   Reply With Quote
Old April 13th, 2003, 12:35 PM   #44
Jim!
Good to hear from you. Hope to see you again soon at one of the shows.
The MA300 cannot be used with the GL1, as the MA300 is an Intelligent Accessory Shoe device (it sends audio through the hotshoe on the GL2). Since the GL1 shoe is "cold," that is, it's not wired and therefore not "intelligent," it is incompatible with the MA300.
Hope this helps, and sure hope to see you here more often!
Old April 13th, 2003, 12:43 PM   #45
Contributor
Thanks Chris! Great to hear from "The Master" himself. Hope things are going well for you.
