24p questions - Page 41 at DVinfo.net
Old April 12th, 2007, 07:39 PM   #601
Just remember if you shoot in 30p and attempt to do a film out at some point you are hosed.
Tony Tibbetts is offline   Reply With Quote
Old April 12th, 2007, 11:47 PM   #602
Originally Posted by Adam Bray View Post
You see TONS of blur in movies. You just don't notice it too much because they attempt to hide it by shooting from certain angles and tracking subjects during pans. It's part of the art.
I'm going to go out on a limb and say whoever told you to shoot 24P and up the shutter does not know what they are talking about. No point in shooting 24P if you're going to crank up the shutter. That defeats the whole purpose to me. You might as well just shoot 60i then. That's my opinion.
Just shoot 24P, 1/48 and pay attention to your angles. Make sure you have a subject to follow on pans.
When I say stuccado look, I refer to a look as though the picture hangs for an instant several times on a pan. I have no problem with MOTION BLUR. I do not see Tons of hang in films. I like the 24P look very much, But, maybe I wasn't clear enough explaining the issue. The hanging, like it moves in steps instead of smoothly is my problem. Thanks. j
John L. Miller is offline   Reply With Quote
Old April 12th, 2007, 11:56 PM   #603
Slash Rules!
Maybe I'm misunderstanding. . .do you mean "hangs" as in, when you pan, the picture doesn't change at a corresponding speed, like it lags, and then moves a few beats later? If so, that sounds like what happens when you're on a tripod, panning, with image stabilization turned on. The IS thinks your pan is the camera shaking, and tries to correct it.
If you just mean strobing, that's just how progressive modes look when panning past certain things and at certain speeds. . .even in 30p (it's the lack of interlace that does it, NOT the framerate). Watch TV/MOvies, you'll see the same thing; it's just like someone said, your attention is usually on whatever is motivating the pan (following someone walking), rather than the background behind them, which probably IS strobing.
Old April 13th, 2007, 08:52 AM   #604
Hear versions of this question a lot. How are you viewing the results, that you find unsatisfactory? If you are watching this on your computer monitor, these are NOT the same results that you will see on your TV set. If you shoot 24p, burn it to a DVD and then watch it, it will have been converted to 60i, the only thing your SD television can display. It won't look like it's been shot in 60i, but it will be 60i.
Upping the shutter speed to solve "staccato" problems is utter nonsense. The more you raise the shutter speed, the more it looks like the combat scenes in Saving Private Ryan, Band of Brothers, etc. - e.g. very staccato, but for an effect. Use 24p - 1/48, or 30p - 1/60.
I started off with this camera as a 24p fanboy - I had to have that "film look". But I am becoming increasingly enamoured of 30p. It still looks closer to film than video, but it's smoother than 24p.
Jack Barker is offline   Reply With Quote
Old April 13th, 2007, 10:31 AM   #605
Images: 1
And above all, the motion on a CRT and LCD is different than that of a projector--I just saw my short film on a 40' screen projected and the frame cadence was soo much better looking--24p, but it seemed so much more impressive.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old April 13th, 2007, 10:34 AM   #606
Ben - film, or digital projection?
Old April 13th, 2007, 08:25 PM   #607
You have to understand that the only reason 24 looks jittery is because most people play it back at 30 fps with a 2:3:3:2 or 2:3 pulldown added. ANY frame rate with an added pull down will look jittery NO MATTER WHAT. If you shoot a frame rate you have to play back that footage at the same frame rate at which you recored it. With 24p the only really practical way is to transfer it to film and project it in a theater. ANY tv or computer monitor you watch it on will be either 30p 60i or 60p (for the most part). There are very few 24p monitors, so a pulldown is usually added (and the monitors that do have 24p are a bit pricey).
So consider where it will most likely be shown. If you shoot 30p or 60i it can only ever be on video (unless you cheat). but if you shoot at 24p you can adapt it to any format later, the same way major motion pictures do. And of course use a 1/48 (180 degree) shutter to take out the motion blur. Motion blur isn't always a bad thing like most people think. If you have no motion blur it looks a bit stop motiony and thats annoying after a while. have fun and good luck.
Alan James is offline   Reply With Quote
Old April 13th, 2007, 09:13 PM   #608
Images: 1
The other thing folks forget to realize. 24P looks smoother when projected in a theater because the theater is DARK. That makes the iris in our eyes open up and then persistence of vision fills in the gaps between the 48fps projection rate (each frame is displayed twice).
-gb-
Old April 13th, 2007, 10:00 PM   #609
The staccato of 24p ?
If you are panning on a subject matter; you'll be fine visually
If you're panning on nothing; there are formulas for shutter speed. I've never heard of the apprehension to shoot 24p for fear of strobing
Learn how to use the camera and it'll be kind to you ! Even the Arri's suffer from this phenomenon. Slow down your pans or ceneter on an object doing the panning (a car or bike rider, et al)
.02
John Hudson is offline   Reply With Quote
Old April 13th, 2007, 11:50 PM   #610
Hudson is correct, if you are noticing the motion in that manner, you are not executing properly. Slow down your pans, make your moves around a subject that draws your eye, etc. You will notice the same thing from a 35mm camera if not moved properly, there is actually a formula for how many feet you can cover in how many seconds...
ash =o)
Ash Greyson is offline   Reply With Quote
Old April 14th, 2007, 10:57 AM   #611
Thanks for all the comments, these are the best suggestions I have heard. Thanks! J
Old April 14th, 2007, 11:53 AM   #612
More tips.... turn OFF all image stabilization and stay away from medium shots with deep focus.
ash =o)
Old April 29th, 2007, 09:29 AM   #613
24p or 60i?
Yes there are links to this question in the forum but the answers aren't clear enough--or my brain simply can't see the answer clear enough so..
I am shooting a surf film in el Salvador-Xl2 and Gl2-The actual surfing is shot at 60i--shutter speed around 1/60 to 1/125 depending on the light---almost always using a circular polarizing filter--with a Custom Preset that was posted on this site for shooting ocean takes.
Question is--I typically leave the setting at 60i even when shooting Lifestyle scenes or Landscape\seascapes--would I get better results if I shot the Lifestyle scenes, etc. in 24p? If so when edited in FCP is there any problem with mixing the 2 speeds?
Ron
Ron Stoecklein is offline   Reply With Quote
Old April 29th, 2007, 10:13 PM   #614
You can mix both but I recommend shooting with the 2:3 pulldown and editing in a normal 60i timeline
ash =o)
Old May 21st, 2007, 08:30 PM   #615
24p, 60i, 30p....letters and numbers or more??
Okay, well I just got my XL2 and need some info and clarification on the 24p, 60i, and 30p. What are the differences and what is better? How do they relate to editing?
Mike
Michael Sweeney is offline   Reply
