XL1 / XL1S various posts - Page 93 at DVinfo.net
Old August 24th, 2004, 03:27 AM   #1381
xl1 Need help please please
My son has taken the battery out.
Which way round does the memory battery go in XL1?
+ and - in relation to the plastic holder.
Many thanks Philip Banyer
Philip Banyer is offline   Reply With Quote
Old August 25th, 2004, 10:02 AM   #1382
Okay to screw polariser onto UV filter?
Do I have to remove my UV filter everytime I want to attach my circular polariser?
This is what I do at present. Or can I simply screw my circular polariser on to the UV fliter? This would save some time, but do I sacrifice something?
regards
Mark
Mark McCarthy is offline   Reply With Quote
Old August 25th, 2004, 02:14 PM   #1383
Warden
It's got a good idea to stack filters. You increase the odds of having issues with flare, vignetting, and reducing overall optical performance (contrast, resolution etc.).
Jeff Donald
Carpe Diem
Old August 25th, 2004, 05:01 PM   #1384
There is normally a sticker next to the battery holder showing you, if this has been removed then the +ve, (widest side) should be nearest the lens.
Carl Walters is offline   Reply With Quote
Old August 26th, 2004, 09:17 AM   #1385
There is also usually a + or - sign molded into the plastic tray indicating orientation. Another sure way is to just install it and if it doesn't work, flip it over.
James Emory is offline   Reply With Quote
Old August 27th, 2004, 09:38 AM   #1386
Battery Life with Nebtek 5"
I'm not sure how long it would run on a BP-915 vs a BP-935. Anyone have experiences with these batteries and that monitor?
Old September 1st, 2004, 02:31 PM   #1387
Blue lens flare under the lights
Howdy,
I'm shooting high school football under the lights and getting lens flare with a UV protector on. Anything else I can do to get rid of it. Another thing is the purple uniforms are coming out blue with manual or auto white balance. It'd be a pain to correct the whole season in post...any suggestions?
TIA,
Randy
G. Randy Brown is offline   Reply With Quote
Old September 1st, 2004, 04:19 PM   #1388
1. Take off the UV filter and relax.
2. Go to www.flarebuster.com and get a Flarebuster. This will help you tremendously under those stadium lights. More info at http://www.digitalprods.com/flare.htm
3. Purple/violet is a problem for most video cameras. This problem goes back a looong way, historically. The chips (used to be the "tubes") just cannot discerne this hue. You could try to white balance using a blue gel or blue card, but don't expect miracles. If you could borrow a jersey, and experiment at home at your leisure, you might have a better chance than experimenting in the stadium. Sure, the stadium uses different light sources than you have at home, but the correction should be similar.
BTW, the Networks used to have the same problem with purples. What did they do? Ignore it.
Wayne Orr, SOC
Wayne Orr is offline   Reply With Quote
Old September 2nd, 2004, 07:19 AM   #1389
Mysterious Vertical Black Lines
I'm using a company XL1 and have noticed with everything I shoot, black lines appear on the left and right side of the frame. They're outside of safe action/title but they're still big enough to notice and they're no good for still images/compositing. Does anyone know why this is happening, is there an internal setting I can adjust?
Cathode Rays Daze
John Hampster is offline   Reply With Quote
Old September 2nd, 2004, 07:37 AM   #1390
Very interesting and helpful post Wayne, I'll try your suggestions!
Thanks a bunch,
Randy
Old September 2nd, 2004, 08:30 AM   #1391
RED Code Chef
No, this is perfectly normal and has been discussed already in
the past a lot of times.
Nothing you can do to change that. You can ofcourse crop the
image or zoom in etc. It's something you will have to live with.
Rob Lohman, visuar@iname.com
Old September 2nd, 2004, 09:41 AM   #1392
OK, as long as I know that all XL1's do that and nothing can be done, I can live with it. Thanks for your input.
Cathode Rays Daze
Old September 2nd, 2004, 05:20 PM   #1393
Generic BP-945
Hey. I know that when it comes to consumer electronics name brand is always better...but when the difference is $100 I have to stop and think. Has anyone used these generic battery packs on their cameras? If so, good/bad/ugly?
Zac Butcher is offline   Reply With Quote
Old September 2nd, 2004, 07:09 PM   #1394
Retired DV Info Net Almunus
Welcome Zac.
Search is your friend here.
Old September 2nd, 2004, 10:20 PM   #1395
Headphones: 7505, 7506 or 280?
Hi,
I'm going to be doing no budget, run-and-gun guerilla shoots, single camera, and I am looking for affordable headphones. I will in most cases be shooting on the field, and not in studio.
My question is, the Sony 7505 is cheaper than the 7506, is the difference significant? Which one is better for field work? What about the cheaper 7502?
Also, purely from the portability/comfort and ease-of-use side of things, is the Sennheiser 280 better or the Sonys'?
Thanks for answering,
Dennis
Dennis Liu is offline   Reply
