Prospect HD 4.0 (Windows) - ISSUES - Page 4 at DVinfo.net
CineForm Software Showcase
Old May 14th, 2009, 12:01 PM   #46
Bruce, I'm new to CF so all my CF files are new. I converted HDV, DV and AVCHD sources with HDLink and they all import. Currently running build 309.
Glenn Babcock is offline   Reply With Quote
Old May 14th, 2009, 12:09 PM   #47
My bad....I misunderstood your post. Still, when I install build 209 it installs one file from the CS4 plugins into my CS3 folder and messes everything up. My reg is pointing to cs4 so i don't understand why this happens but deleting that one file from cs3 fixes all the hangs when importing files so far.
Originally Posted by Bruce Gruber View Post
Hi Marty
I am sorry I meant to say my floders have the files in them like Glenn has listed for his folder contents. I would type it all but it would take forever my iPhone. I am at my day job now.
Glenn Is this working for you on old CF files or the ones you just re captured?
Marty Hudzik is offline   Reply With Quote
Old May 14th, 2009, 12:22 PM   #48
I will check she I get home was it the I am child CH importer file?
Bruce Gruber is offline   Reply With Quote
Old May 14th, 2009, 12:27 PM   #49
Hi Marty what files do you have in your mediacore folder for cs3
Old May 14th, 2009, 12:37 PM   #50
I'm at my day job too where I am running CS3 without Cineform Support so I cannot check until this evening.
Old May 14th, 2009, 02:21 PM   #51
Thanks Marty
Dave van you list the files that should be in the mediacore folder forCS3 vista/64
And the ones to look out for that do not belong there
Thanks Bruce
Old May 14th, 2009, 06:00 PM   #52
Ok it went to my xp 32bit machine with CS3 loaded. I loaded CF 4.0 build 209 and when I try to import a CF file I get a serious error and CS3 closes. Any suggestions?
Old May 15th, 2009, 10:25 AM   #53
Any help on previous post? I just Installed NEO hd on my xp cs3 and the import CF files worked first light worked fine. where as with Prospect HD 4.0 build 209 it will not import CF files t all. XP or vista. I have not tried Neo HD on vista/64 I do not want to keep installing and un-installing?
