#61 |
Re: Canon 2012 NAB teaser
My guess if is not just a screening:
4k with Raw |
#62 | |
Jim Martin Filmtools.com |
#63 |
When the Canon 5Ds video first appeared the most surprised group of people was the Canon video camera folk.
They probably couldn't believe it and I'd say they complained bitterly to the Head Honcho. Imo it's been shown they work in separate vacuums from each other and it's all to do with trickle down technology in each others field. HH wanted to them to share one large Canteen but it goes way back to the Ninjas. Cheers.
Support your local movie theatre, they need it. |
#64 |
Space Hipster
If a DSLR comes with the Canon XF code, that's a major win. It's a true broadcast 50mbps, 4:2:2 codec. I'd be all over that. I have an FS100, and it's a great camera, but the AVCHD codec is a bit lacking.
#65 |
Starway Pictures
Haven't we learned from RED that it's very difficult to do that much video processing and recording inside a housing as small as DSLR? And that the other caveat about crunching that much math and moving that many pixels around creates a LOT of heat?
Not sure if a 4K 50mb/s codec DSLR is even technically feasible outside a test-bench. |
#66 |
Good point and which shows that in my mind, we are not ready for 4k on a large scale.
Looking back at the dawn of the HD era, there was a flood of under resolved and overly compressed products that were released just to say they were HD and for sale. Now that it is shown that true HD with lower levels of compression looks just great even for cinema. At this point I see 4k as pure marketing and it would be shame for Canon to release a 4k DSLR when they jury is still out on the HD versions. |
#67 | ||
The 50Mbs codec works very well for processed 1080, but it's a 1080 codec, period. Any 4k recording would need something totally different. A camera with 4k RAW and 1080p 50Mbs would (IMO) be a very good balance. Use the 50Mbs codec for broadcast work which has a relatively quick turn around time, and 4k RAW for most post control and when there's time and resources to do it. It should be possible to do both satisfactorily with the C300 chip - but is this a DSLR? "DSLR" implies a camera optimised for stills, and the 8 megapixel chip is low for high quality stills. |
#68 |
4K can be compressed to 50 Mbps - it can be compressed to 0.5 Mbps if you want it to happen. Nothing in the compression specs forbid it.
The interesting thing is that the 50Mbps 4:2:2 Interframe specification was adopted by broadcasters for 1080/720 video (defined by SMPTE) only, as David mentioned. To get roughly the same 'quality' at 4K, one would need approximately 200-250Mbps - but then again those deciding the specs will also have to look at the current broadcast pipeline, technologies and bandwidth available, not to mention that 4K on home screens are a wasted effort (at present) at regular viewing distances and light levels. The DCI lower limit for compression, for 2K and 4K, are exactly the same. I find that ludicrous.
Get the Free Comprehensive Guide to Rigging ANY Camera - one guide to rig them all - DSLRs to the Arri Alexa. Last edited by Sareesh Sudhakaran; March 16th, 2012 at 09:34 PM. Reason: typo |
#69 | |
If it is a DSLR it possible that will derive 4K from 30Mpxls and at the same time be a full fledged still DSLR. Canon needs to address Nikon's D800 sooner or later. So if its not at NAB, it must be within a year. If I try to summarize most opinions, it will either be a C100 1080p 50Mbits, resembling C300, but with less feature and (hopefully) more reasonably priced or a 4K Raw DSLR with a price TBA I would say 60%-40% it will be a 4K DSLR. |
#70 |
It should be a 4K DSLR for B cam applications in DSLR form factor. Great for rigging shots. Price is definately going to be $10k in my guess
Firewerkz Films SGP |
#71 | |||
But I wasn't really thinking of a DSLR anyway when I referred to a "camera with 4k RAW and 1080p 50Mbs" - rather a big brother to the C300. Quote:
More pixels are coming A suggestion that a high megapixel camera is coming from Canon, and could be introduced near the end of 2012. Alongside the camera would come new ultra wide angle lens(es). It was suggested both a zoom and a prime in the area of 16mm. I warn that this sort of conjecture will be a regular occurrence going forward I think. There is a large number of people in the community that desire a 35+ megapixel camera from Canon. NAB 2012? Some have suggested the upcoming 4K DSLR will be the high megapixel camera. I don’t believe that to be true, as the high megapixel count is definitely a request of the photographic community, and paying for high end video features is probably not something that would make the segment too happy. Rumour and speculation, obviously, but it would make sense. PRIMARILY for stills, but if twice the 4k pixel count hor and vert it could be read relatively easily, (same method of 2x2 as used in the C300). And whilst the resolution may be "high end video",I doubt most of the other aspects could be described that way, when compared to the C300. "4k high end video" would imply high bit depth RAW - I don't see there being anything like that in any such product. Quote:
#72 |
But doesn't Canon's DSLRs already process 1080 at 44Mbps? 50Mbps isn't an issue, like the GH2 hacks show.
Get the Free Comprehensive Guide to Rigging ANY Camera - one guide to rig them all - DSLRs to the Arri Alexa. |
#73 |
I'll go back to my original opinion.
I think the hottest, most competitive camera they could produce would be a dedicated 1080 film making DSLR with the XF codec. Only the smallest niche of users need or will need 4k. 1080 is and will be, for camera cycles to come, the standard for all but cinematic work. But give it a 50 mbps 4:2:2 robust codec for grading and green screen, full use of the EF lens line, 35mm full frame field and depth of view and you could have a camera that would be to this market what the original 5DII was three years ago. With the buttons dedicated to video oriented controls and a battery grip with XLR input and you've bridged the divide. |
#74 |
That is exactly the camera I am hoping for and why I have not rushed out to buy a 5DMkIII. As to if we will get it I am currently rather cynical. After all, Canon might see it robbing sales from the C300.
However, if Canon don't fill this customer need soon the others surely will.
Andy K Wilkinson - https://www.shootingimage.co.uk Cambridge (UK) Corporate Video Production |
#75 |
Space Hipster
So basically, what most of us want is a Canon XF105, but with a large sensor and an EF lens mount. Perhaps in a DSLR body, perhaps not. Methinks you could have a better layout of video-centric controls on an XF body design. All for under $10,000, hopefully a lot less.
The XF105, with its 8-bit, 4:2:2, 50mbps, broadcast quality codec, retails for $4,000. It's hard to believe that the C300, with the same codec, quadrupled in price compared to the XF105. Just how expensive is that large sensor and accompanying hardware? You'd think Canon could figure out a way to squeeze the EF mount and hardware into an XF105 body, maybe even an XF305, for less than $16,000. Sony managed to put a large sensor and an E-mount in the VG10/20, basically a consumer Handicam design. It's hamstrung with an AVCHD codec, but physically a large sensor can fit into a small camcorder. Maybe that's why there's been such shell-shock over the C300 price. |
