Any site / server problems -- post here. - Page 3 at DVinfo.net
Go Back   DV Info Net > The DV Info Network > DV Info Net Announcements
Important news relating to the DV Info Net site and these message boards.
Old December 8th, 2008, 11:33 PM   #31
Images: 3
Gallery problem
When I try to access the gallery I get "warning: invalid etc" . Have seen this for last week or so. Anything obvious? Vista?
The message is:
Warning: Invalid argument supplied for foreach() in /export/sites/dvinfo.net/docs/gallery/gallery_global.php on line 352
Warning: Invalid argument supplied for foreach() in [path]/includes/functions_gallery.php on line 1067
the last being repeated and repeated and .........
Last edited by Serena Steuart; December 9th, 2008 at 12:06 AM. Reason: to include actual warning
Old December 9th, 2008, 07:53 AM   #32
*sigh* Yeah, it's definitely broken -- I'll probably remove the link. Right now the best way to share pictures here is to include them in a post as attachments (manage attachments below the text area input field when making a post), or if that option isn't present, then add pictures to your profile (Controls > Pictures & Albums > Add Album > Add Pictures), and post a link to them, such as this one:
http://www.dvinfo.net/conf/members/c...t-members.html
http://www.dvinfo.net/conf/members/c...yd-shiner.html
As far as the old Galeery is concerned, my primary goal is to preserve all of the images and associated metadata and export everything to a new, improved gallery solution -- yet another important item on a seemingly endless list of things to do around here.
Old December 9th, 2008, 05:55 PM   #33
Images: 3
OK. One of those things....
Old December 9th, 2008, 06:24 PM   #34
One of *many* things.
We're pedaling as fast as we can.
Old December 10th, 2008, 01:01 PM   #35
Is this another new problem?
When attempting a search, I've started getting the error message:
"You answered the NoSpam! question incorrectly. Please reevaluate your answer or, if you found yourself unable to answer it, you can refresh for another question if the administrator has enabled multiple questions. If you find yourself repeatedly unable to answer the NoSpam! questions, please contact the forum administration".
Old December 10th, 2008, 01:34 PM   #36
Images: 1
Colin, where are you searching from, the drop-down search menu?
Jenn Kramer is offline   Reply With Quote
Old December 10th, 2008, 01:58 PM   #37
I get the same message from using the drop down search menu. If I'm signed in it works however.
Edward Phillips is offline   Reply With Quote
Old December 10th, 2008, 03:58 PM   #38
Yes
That's what seems to be happening now.
I used to be able to search from the drop down menu without logging in. It's not that much of an inconvenience, but the error message doesn't seem appropriate.
Old December 10th, 2008, 04:04 PM   #39
Remember, there are two ways to search on DV Info Net -- through the forum software itself (the "search" link at the top of any page), and the Google box at the bottom of any page. You can search down to two-letter strings, there's no forced timeout between searches; we try to make it easy around here.
Old December 10th, 2008, 04:47 PM   #40
And indeed you do Chris! I only mentioned it because the lazy way used to work for me.
Thanks for the reminder of the merits of the Google box - I still forget about that sometimes.
Old January 16th, 2009, 07:50 PM   #41
Log in, Post, Log in not recognized, post lost
I visited DVI on my laptop, generally not used for visiting DVI. I logged in, reviewed topics of interest, and decided to reply to a thread. Spent a good amount of time composing a reply. When finished, I submitted the reply, and was promptly notified I was not logged in. Better than 30 minutes of carefully composed response was gone forever.
Clearly, something is decidedly wrong! I was most definitely logged in.
This is the second time I have lost a rather detailed post under the same circumstances.
I'm following the prompts, why is the system failing?
Waldemar
Waldemar Winkler is offline   Reply With Quote
Old January 16th, 2009, 08:14 PM   #42
I'll pass this along to Jenn, who manages our server... meanwhile, it's always a good idea to compose long posts in Notepad or some similar text program, just to be on the safe side. Sorry for the trouble, I know what it's like to lose a carefully written article.
Old January 16th, 2009, 09:18 PM   #43
Waldemar.
If you are inclined like me to compose replies on-line and it grows and you run off the end of the time limit, perhaps adopt as I have, the practice of "select all" the body of the text, "copy", then "submit".
If you then find you must log in again, fill in both log in spaces you will be offered, then click "log in" on the top right one. I don't know why both spaces must be filled, or why you must click on the top right. It simply may be a co-incidence or something weird about my computer, probably something weird about myself but let's not go there.
You may find you are returned to a "done" screen but everything is blank. Other times you will be returned to the message and find your reply has arrived.
Sometimes you must go back to the portal and work your way back to the message where you will find it has arrived. If everything hangs, it will be because somebody has replied about the same time as you. Your message will not be there. There will be another.
That's when you start another reply, "paste" your copied message into the space and click "submit".
Old January 17th, 2009, 06:15 PM   #44
I have encountered this behavior several times in the past too. Now - I no longer post long replies directly onto this forum. I opened up Notepad, keyed in the reply into it, AND SAVE the reply into my notebook HDD, then copy and paste into the forum. I think there is some timeout mechanism at work behind the scene.
TingSern Wong is offline   Reply With Quote
Old January 17th, 2009, 06:24 PM   #45
I thought I'd lost one recently because it told me I wasn't logged in when I hit submit and there seemed to be no trace of it, so I reposted (I had kept a copy) but when I quit the browser and logged in again, there was a double post.
Colin McDonald is offline   Reply
  You are here: DV Info Net > The DV Info Network > DV Info Net Announcements
