NLE Mac / Final Cut questions from 2004 - Page 9 at DVinfo.net
Final Cut Suite
Old January 23rd, 2004, 01:02 AM   #121
Umm, that was quick. Did I blink and miss it?
So I went into Disk Utility and the 160 gig hard drive showed like this:
149.05 GB WDC
Media
"Media" being the name and there being no partitions on the drive. So I clicked on "Media" and went to Erase. It was in "Extended" format already and after having read, "http://www.kenstone.net/fcp_homepage/mac_not_mother.html" I kept it that way - on Mac OS Extended. I hit Erase and it cleared everything in a matter of about 5 seconds.
Being raised on a PC, that felt too quick. Should I have highlighted the "149.05 GB WDC" and hit erase there or am I just being paranoid? I checked the drive and indeed, it was all gone...
Joshua
Joshua Kopple is offline   Reply With Quote
Old January 23rd, 2004, 01:43 AM   #122
minor Setups question
What is the difference between the Setups
DV-NTSC
and
DV-NTSC 48 kHz-FW Basic?
Shawn
Breakthrough In Grey Room
Shawn Mielke is offline   Reply With Quote
Old January 23rd, 2004, 05:09 AM   #123
Warden
I just writes a new directory that ignores all the old files, so it looks empty. When you start capturing to the drive it overwrites the old files. If you want to format the drive (write zeros and ones) that will take hours.
Jeff Donald
Carpe Diem
Old January 23rd, 2004, 10:37 AM   #124
clip appearance when FCP3 --> FCP4
Just upgraded to FCP4, everything works fine, even the FCP3 project that I have to finish was imported without problems (quite a relief that...)
I noticed though that there is a difference between some clips' display in the bins: some have the standard appeareance, others have jagged edges.
Both types of clip play ok though, have looked in the manual but couldn't find out what this is. No differences in clips when I go to "item properties".
Not really a problem, but I would like to know what this means. Btw I've only opened a FCP3 project so far.
thx in advance
Michiel
(I wanted to attach a picture of a screen grab but can't attach anything to this message. If you want to help but don't know what I'm talking about send me an email and I'll send the screengrab over)
vanderzeeuw@planet.nl
Michiel van der Zeeuw is offline   Reply With Quote
Old January 24th, 2004, 11:05 AM   #125
Contributor
Help! Low quality DV preview in FCP4 after trashing prefs. Fix?
Hi all, if anybody can please help me out with this...
A few days ago I took my PB to a friend's so we could rescue a project and print it to video (his boot HD had died). We were able to boot off my PB as a FW drive and print his project, a great lifesaver... we could never have got away with something like that on PCs. Anyway, after getting back home my FCP4 would ask me for his disks, and there seemed no way of reconfiguring my setup so I trashed some FCP preferences files (don't remember exactly which). Now, everything works as usual BUT i am dropping frames and seeing something like half-res, half-frame rate video previewed over firewire. I don't want to have to reinstall everything, but I will as a last resort. Does anybody have a clue about what might be going on? Of course I stupidly did not save a backup of the files I trashed. Any other solution before resintalling the whole thing? Thanks...
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands.
Ignacio Rodriguez is offline   Reply With Quote
Old January 24th, 2004, 04:12 PM   #126
Warden
Re-install if you don't know what you trashed. Just trashing preferences won't do what you say. When you restart after trashing the preferences (and emptying the trash) FCP recreates new preferences, using the default settings. You probably trashed a file other than the preferences.
Jeff Donald
Carpe Diem
Old January 24th, 2004, 09:43 PM   #127
Contributor
Oh it did. It just seems that when determening the defaults for this machine something when wrong, it's as if FCP were set up to run on a much slower computer.
Old January 24th, 2004, 10:02 PM   #128
Warden
If you think you only trashed the preferences, then do it again and see if the results are the same.
Jeff Donald
Carpe Diem
Old January 25th, 2004, 08:46 AM   #129
RED Code Chef
DV-NTSC is 12 bit 32 kHz instead of the 48 kHz for the other?
On my NLE [pc] the difference between the presets is listed so
you can see for yourself.
Rob Lohman, visuar@iname.com
Old January 25th, 2004, 08:56 AM   #130
RED Code Chef
Michiel, you can't attach files within these boards indeed. If you
want I can host a screengrab for you at my site. Shoot me an
e-mail at visuar@iname.com
Old January 25th, 2004, 09:07 AM   #131
Retired DV Info Net Almunus
Michiel,
Go ahead and send me the screengrab and I'll see if I can help you out. If not, I'll share it with some of the other Mac wranglers... between all of us, we'll track it down probably.
John Locke
SursumFilms.com
John Locke is offline   Reply With Quote
Old January 25th, 2004, 09:10 AM   #132
Three-way split screen in FCP?
I'm weighing different ideas on how to split the screen with three vertical images (a three-way phone conversation showing all the people at the same time)... and I'm sure there are more ways than that.
Anyone have any input on what would be the best way to do this in FCP?
John Locke
SursumFilms.com
Old January 25th, 2004, 09:47 AM   #133
RED Code Chef
I've put the screengrab up for all to see: www.visuar.com/DVi/zeeuw.jpg
Old January 25th, 2004, 11:10 AM   #134
Some cameras use the "firewire basic" protocol instead of firewire. All Sonys are firewire, most Canons are firewire basic.
http://www.apple.com/finalcutpro/qualification.html <-- check there.
Also check that the capture settings match your camera footage. 32khz audio sampling rate corresponds to 12bit on your camera, and 48khz to 16bit. You should set your camera to record 16bit unless you can't or want to record 4 channels on a XL1s. If your footage is already 12bit (in the camera) then capture using 32khz.
Old January 25th, 2004, 11:12 AM   #135
FCP3 captures clips differently than FCP4, maybe the jagged edge is to indicate the difference? That's my wild guess.
