excessive encoding time? - Page 2 at DVinfo.net
Final Cut Suite
Old May 30th, 2007, 05:49 AM   #16
Originally Posted by Drew Curran View Post
I also use this method, as I found HDV to slow expecially for long clips. I also found that I had a greatly reduced number of realtime effects when using HDV on the timeline. I have a G5 dual 2.0 with 4gb ram. AIC is just faster.
Drew
Thanks for all the replies. Drew, do you mean that you capture as AIC? Or you capture as HDV and then convert to AIC? If the latter, how is that done? Thanks.
Dave Lammey is offline   Reply With Quote
Old May 30th, 2007, 07:05 AM   #17
Hi, Dave,
I capture to HDV and then use Batch Export feature to convert all clips to DVCProHD (720p). On a quad G5 it takes roughly 2:1 realtime (2 min/1 min).
If my sequence uses lots of overlays and intricate, detailed graphics I batch export to AIC instead.
Greg Penetrante is offline   Reply With Quote
Old May 30th, 2007, 07:09 AM   #18
Originally Posted by Greg Penetrante View Post
Hi, Dave,
Ah, thanks. So here's the dumb question: why convert to DVCProHD? Are you working with 1080i footage originally (from a Sony FX1, for example), and if so, is there any problem converting to 720p?
Old May 30th, 2007, 07:12 AM   #19
Turbo 264 fun
Just bought an Elgato Turbo264 USB stick...
DVCPro 720p/24 to...
iPod Standard (640x480): 17 FPS (!)
iPod Regular (320x240): 60 FPS (!!)
AppleTV (800x480): 17 FPS (!)
Those encode time clearly beat Compressor. The files are also 5-10% smaller. Quality is the same as Compressor multipass.
So far, so good!
Old May 31st, 2007, 10:46 AM   #20
Dave,
I find that DVCProHD is better to work with because 1) Each frame is individual; 2) FCP runs faster with DVCProHD workflow.
I find that converting interlaced to progressive sacrifices a bit in image quality. That said, if you want to go to 720p then the better compromise is 720p60 from 1080i60.
best regards
