NLE Mac / Final Cut questions from 2002 - Page 70 at DVinfo.net
Final Cut Suite
Old November 5th, 2002, 12:24 PM   #1036
donking!
Posts: n/a
It's actually up to 3.5.3 now, which I do have. No one else on the Avid site is complaining about this, so that's why I suspect I'm doing something wrong. Any other ideas?
Old November 5th, 2002, 06:01 PM   #1037
Jeff:
Hardware wise:
Mac G4 dual 1.25G
Two internal 120G ATA drives
One external 120G Firewire drive - Que QPS-525
Panasonic AG-DV1000 MiniDV deck
Software wise:
OS 10.2.1
FCP 3.0.2
QT 6.0.1
The sources are from two different cameras (Gl1 and a high-end Sony MiniDV consumer model) as well as the usual Photoshop, .wav and .aiff things. The video just flickers a few random squiggles until I stop the cursor on the time line, and then it shows as a still on the video monitor just fine. I tried to correlate the changeover between the unsynced gibberish and clean video with render/RT points but there doesn't seem to be and connection there.
Thanks for your interest.
Dave Sweet is offline   Reply With Quote
Old November 5th, 2002, 09:25 PM   #1038
Jeff:
After reading a few more threads on this forum, I went back and transferred every one of the 32 source clips to the second internal ATA drive, then shut the external firewire drive completely off, relinked everything to the new drive and re-rendered. And voila...this time it worked. Now the video is clean and print to video works fine. Could it have been a firewire bottleneck, or is this external firewire drive a snake in the grass? I've never had any problems with it working with OS 10, either on my G4 or platinum powerbook.
Sorry for the inconvenience.
Old November 5th, 2002, 10:14 PM   #1039
Warden
It could be a couple of things. Try reformating the FireWire drive. If you've had it for a while it could be the wrong format. In the Utilities folder is a program called Disk Utility, run the Erase part and select Mac OS Extended and erase it. You might also try a new FireWire cable. Check the Que web site for any bugs with 10.2.1 and see if there are any patches to download. Do you have anything else on the drive? If so try to keep only FCP media on it. I seem to recall reading something about Que drives and FCP. I'm not 100% positive but I think there may be a problem with the drives and compatability with FCP. I'll dig a little and see what I can find.
Jeff
Old November 6th, 2002, 03:57 PM   #1040
Retired DV Info Net Almunus
New PowerBooks and iBooks
Oooo...
Apple today announced the new PowerBooks with 1Ghz G4 processors -and- internal SuperDrives (DVD/CD burners). New iBooks were also announced, as well as price reductions across the line (they -were- a bit pricey).
For more information go to:
http://www.apple.com/powerbook/
Old November 6th, 2002, 06:10 PM   #1041
DP@VAGFOTO
Posts: n/a
GL-2 to VHS deck output problem
I have just cut my new showreel on imovie and exported it to my gl-2 with no problems.
The trouble started when I tried to dub the mini-dv tape information to VHS with my S/VHS deck.
Tried all of the combos of plugs and settings the GL-2 manual sets forth
and anything else I could think of with no luck. Hoping I am just missing some tid bit someone out there knows about and not have an incompatibility problem that cannot be solved...?!
Old November 6th, 2002, 10:36 PM   #1042
What exactly is the nature of your problem? No footage being transferred? Footage looks bad? Etc...
Old November 6th, 2002, 11:19 PM   #1043
Woohoo! More toys!
John Locke
SursumFilms.com
John Locke is offline   Reply With Quote
Old November 7th, 2002, 08:18 AM   #1044
DP@VAGFOTO
Posts: n/a
figured it out
thanks for asking Ken. Basically I was getting no image and then blue screens with vague vague hints of the images on the reel. turns out my remote for the deck was low enough on batteries that when I thought I set it to L1, it did not do it and there is no way of setting this on this deck without the remote. anyway, got it working and it looks great. cheers!
Old November 7th, 2002, 07:32 PM   #1045
Firmware Update to SuperDrives
Apple posted an update to the G4's SuperDrive firmware today. Apparently this provides a solution for using 4x media in the drive (previously a problem), as well a few other fixes.
The update is available through your System Preferences > Software Updates facility under OS-X. But I highly suggest reading about this update first to determine if you need it at:
http://docs.info.apple.com/article.html?artnum=86130
since the process cannot be undone.
Old November 7th, 2002, 10:35 PM   #1046
which way to go?
I am looking to buy a portable hard drive for video, what is the best? I have had 2 Lacie drives crash on me after moving them in my car a few miles, and one was 2 days old!?!?! I need a RELIABLE portable drive. Any suggestions?
...all I need is a crumb!
Patrick Coker is offline   Reply With Quote
Old November 8th, 2002, 12:31 AM   #1047
My personal recommendation...
...is WeibeTech.
http://www.wiebetech.com/
I use both a 120Gb Super DesktopGB and a 40Gb MicroGB for FCP3 work and can say they've been excellent values and very reliable.
Of course maybe you should first check your car's suspension before investing more in Firewire drives. ;-)
Old November 8th, 2002, 03:47 PM   #1048
...that is cold....
Thanks for the info
Old November 8th, 2002, 06:07 PM   #1049
I've got the 800mhz powerbook, is it possible to buy the Superdrive and replace my current DVD/CD-R/RW with it. Or should I wait for a firewire DVD-R/RW?
Amacitia Reddit Honores
(Friendship Brings Honour)
Guy Pringle
Silver Reflections
guypringle@yahoo.com
+27(0)83 256 8566
Guy Pringle is offline   Reply With Quote
Old November 8th, 2002, 06:07 PM   #1050
How to rip DVD into Final Cut Pro?
Do you know how we can take video & audio from a DVD and use it in Final Cut Pro? This is not about stealing from Hollywood: Someone made a DVD of a business conference and one of the speakers at that conference wants us to excerpt their speech for use in another production. We can't seem to figure out how to get the DVD content into FCP!
Many thanks for your kind advice.
Scott Shuster
New York
http://stratostream.com -- dance & fitness videos
Scott Shuster is offline   Reply
