Anyone read this? - Page 2 at DVinfo.net
Old November 19th, 2004, 08:33 AM   #16
Outer Circle
Thanks. I'll try it. If it doesn't work I'll just walk over to the Internet cafe. I actually have almost enough spare cash to buy one, without using the plastic. I was planning on getting one shortly after X-mas. So I'd like to find out as much about this possible problem as I can. "Chucky" told me that Pana wants to keep this under wraps; and my contact never got back to me.
Old November 19th, 2004, 02:41 PM   #17
I checked my GS400 and can not hear that special tape sound. I suspect that Panasonic must release top quality product in Japan compare to the rest of the world, and that let me believe I made a right choice to buy the camera in Japan. 8 )
Regards
Leigh
Leigh Wanstead is offline   Reply With Quote
Old November 19th, 2004, 08:53 PM   #18
Outer Circle
You are most likely correct. However, I hope you didn't end up with a NTSC model to use in PAL country. :-))
Old November 19th, 2004, 09:55 PM   #19
<<<-- Originally posted by Frank Granovski : However, I hope you didn't end up with a NTSC model to use in PAL country. :-)) -->>>
You are right.
I own JVC GY-DV5000U and PANASONIC GS400. Both are NTSC model and I live in New Zealand which use PAL standard. My future customer in my mind lives in USA, so I don't worry that too much. 8 )
Regards
Leigh
