Petition for Improvements for the HVX200 - Page 3 at DVinfo.net
Old February 14th, 2008, 07:10 PM   #31
Go Go Godzilla
Images: 15
Originally Posted by Roshdi Alkadri View Post
so the new cam panasonic will give us will be good for both ENG/EFP and Digital Filmmaking, it will offer p2 support, more latitude, no noise, full raster 1080p, AVCHD...
Just to be clear, AVCHD is probably being confused (as it often is) with AVC-Intra. AVCHD is a consumer codec and similar to HDV is long-GOP, although it's supposed to be a slightly more efficient long-GOP. It's not a codec you'd want on a professional camera - AVC-Intra however, is the professional version you do want.
Old February 14th, 2008, 07:57 PM   #32
Agreed. AVCHD is a theoretical step up from HDV. It's more efficient, offering some combination of smaller files or higher quality. Both are long GOP.
AVC-Intra is a theoretical step up from DVCProHD for similar reasons. Both have fully independent frames.
I think a pro can still use AVCHD - just as a pro can currently use HDV. But it's for the bottom tier of the market. And it's not the right solution if you need quick turnaround.
Jon Fairhurst
Old February 14th, 2008, 09:35 PM   #33
dope. sorry, i meant AVC-Intra, which is a step up from the dvc pro HD.
I was hoping for RAW files, but i know good luck
Roshdi Alkadri is offline   Reply
