SDHC substitute for SxS cards - Page 39 at DVinfo.net
Old October 12th, 2008, 07:56 PM   #571
I had to pull the Trandscend 8 GB card in and out about four times before the cam recognized it. I tried to insert another card with IOC-9750 adapter into slot B while slot A was recording. Error message Slot A restore Media. This adapter may work better with the Sandisk cards. I do not have any to test still waiting on my (4) 32gb Sandisk SDHC cards to arrive.
Ditto Steve I'm sticking with the Kensington too.
Old October 12th, 2008, 08:29 PM   #572
Hmmm...
With Sandisk Extreme III, the only issue I had with IOC was that when you switched the EX1 from camera to media player mode, you'd have to pull the IOC adapter out, then reinsert it back in - because *sometimes* the cam would not see it otherwise.
Alex Raskin is offline   Reply With Quote
Old October 13th, 2008, 07:06 AM   #573
Cards that will work with both: nanoFlash and EX (SxS alternative)
Sandisk Ultra II 15Mb/s seems to be working best as SxS alternative - but:
I would like to buy cards (about 20 to 30) that work with both:
nanoFlash and EX (with Kensington-adapter)
For nanoFlash
http://convergent-design.com/
recommend
Transcend 32GB Compact Flash Card (133X Speed)
http://ec.transcendusa.com/product/I...mID=TS32GCF133
They have not tested any other cards with it.
Will the Transcend 32GB Compact Flash Card (133X Speed) be o.k. as SxS replacement using with a kensington adapter? Convergent say they are the cheapest cards and "have sufficient performance for data-rates up to 100 Mbps (Long-GOP or I-Frame)."
Is there anybody else who wants to buy nanoFlash and is facing the same problem: What cards to buy for BOTH?
Thomas Diehl is offline   Reply With Quote
Old October 13th, 2008, 07:14 AM   #574
Images: 10
Thomas...
The Kensington uses SDHC cards. nanoFlash uses CF cards. Two different beasts.
Old October 13th, 2008, 07:17 AM   #575
A very important point, Thomas - I'm in the same boat :)
Old October 13th, 2008, 07:21 AM   #576
Google "SD card in Compact Flash adaptor" - Russian Doll meets High Tech Storage.
Rats, I'm now cursed because I can't stop hearing 'Dem Bones' rattling around in my brain. The SD's connected to the... Compact Flash; the Compact Flash is connected to the... PCI Bus; and so on.
EX1 x2, C100 --> FCPX & PPro6
Old October 13th, 2008, 07:30 AM   #577
For nanoFlash
HDV To HD-SDI Video Converters Professional Video Equipment HDMI To HD-SDI Television Studio Equipment
recommend
You can not use compact flash cards with the Kensington adapter. We are using the SDHC cards. I have tried several compact flash adapters with the Ex1 None have worked so far and the cards stick to far out of the cam with the compact flash adapters.
These cards are so cheap compared to the SXS just buy two sets SDHC and Compact flash and call it a day.
Old October 13th, 2008, 07:34 AM   #578
Images: 10
SDHC cards are so cheap, they're practically disposable. If you're used to archiving projects on a hard drive, it's cheaper and easier to store and archive on SDHC cards.
Old October 13th, 2008, 08:34 AM   #579
I'm I missing something in the math?
1.5 TB hard drive is $190
Two DL-DVD (16GB) is a little over $4
How is 16GB SDHC cost per GB cheaper than either?
Now if you're comparing the cost of SDHC compared to HDCAM tape maybe that's competitive.
Old October 13th, 2008, 08:37 AM   #580
Images: 10
What I meant was that they are cheap enough to be used for archiving, not that they're cheaper than a hard drive. . That's what I'm doing in my business; and, my customers are happy with that solution. Each customer buys their own archival media. Given the choice, most of my customers opt for SDHC over a hard drive or SxS card.
In the context of this thread, my point is that worrying about using the same flash media on nanoflash and a Kensington type card reader is rather a waste of time.
Gotta love the way the internet is so argumentative.
Old October 13th, 2008, 09:13 AM   #581
Damn, now I'm cursed to! Very funny!
Sony EX3, Vegas 9.0 64bit, Windows 7(64), Core i7, 12GB, RAID1 & 0, HotSwap SATA, 30" LCD(2560x1600)-GTX285 & 24" LCD(1360x768)-7800GT
Ted OMalley is offline   Reply With Quote
Old October 13th, 2008, 10:55 AM   #582
I'm no longer interested in measley 32GB card solutions. Here is what I've put together.
Sure takes care of the weight distribution problem.
Old October 13th, 2008, 03:33 PM   #583
Ted will it work with the EX1?
Old October 13th, 2008, 03:48 PM   #584
Only if you have updated the firmware.
Old October 14th, 2008, 07:18 AM   #585
Sandisk HD 16gb
Has anyone tried this Card Sandisk HD 16gb?
SDSDHV016GA15 SanDisk 16 GB Video HD SDHC Memory Card
Brian Rhodes is offline   Reply
