New 7" HDSDI and HDMI Monitors from Marshall - Page 6 at DVinfo.net
Old February 21st, 2011, 01:29 PM   #76
Re: New 7" HDSDI and HDMI Monitors from Marshall
The Marshall 70XP now comes with loop-thru on the HDMI ! ! ! ......for about $80 more than the previous 70XP
Jim Martin
FilmTools.com
Jim Martin is offline   Reply With Quote
Old February 21st, 2011, 02:22 PM   #77
Jim, do you have a link to that "loop-thru" version? I can't find any listing that shows anything apart from the single input version.
Old February 21st, 2011, 06:53 PM   #78
Here's the link ........
Marshall Electronics - V-LCD70XP-HDMIPT 7" Small Portable Field / Camera-Top DSLR LCD Monitor with HDMI Loop-Through
Jim Martin
FilmTools.com
Old February 21st, 2011, 07:13 PM   #79
Thanks for the link, Jim. One related question: If you have either the HDMI model or the SDI model and feed it a signal, will there be any video appearing on any of the other connections or does the signal only appear on the loop-thru connection?
Old February 22nd, 2011, 12:28 PM   #80
You send it in HDMI, it goes out HDMI. You send it in HD SDI, it goes out HD SDI. No converting or cross pass through.
Jim Martin
FilmTools.com
Old May 10th, 2011, 11:42 AM   #81
a question for on camera monitor. should i go with sdi or hdmi. is there a gret loss of quality with either of the two. i am looking at the 7" marshall monitor.
Thanks in advance,
Dano
Dano Motley is offline   Reply With Quote
Old May 10th, 2011, 11:55 AM   #82
DVCreators.Net
Thanks in advance,
Dano
If your camera has both HDMI and HDSDI outputs, I'd suggest going HD-SDI. The connector is solid and you can perform much longer runs with HD-SDI if needed. In my experience, the quality of the image will be the same in runs under 50' for both HD-SDI and HDMI.
Of course the HDMI monitors are less expensive if cost is a concern. However, being able to throw a right angle adapter BNC and have a solid connector that won't break in the field is a big concern for run n gun shooting.
Here's a picture of cool new coiled flexible HDMI cable called the Flexicord I bought and broke on first use.
Guy Cochran
Old May 10th, 2011, 12:43 PM   #83
great advice. thank you.
dano
