Need New Audio Solution - Page 3 at DVinfo.net
Old September 4th, 2015, 08:37 AM   #31
Re: Need New Audio Solution
Originally Posted by Peter Rush View Post
Michael the specs on the DR-10C say they are 1" deep which is pretty much the same as a H1 - I think I might get a few grooms not happy with that bulge in their tailored jacket - back to the drawing board?
It's actually really small (much smaller than my Sennheiser G3 transmitter). It only uses a single AAA battery so it's much lighter than the G3 too, plus there's no antenna.
You can check out this really nice review where it's compared to the Zoom H1 so that you can see the size difference:
Michael Silverman is offline   Reply With Quote
Old September 4th, 2015, 08:44 AM   #32
Originally Posted by Michael Silverman View Post
I just purchased two Tascam DR-10C recorders and they are FANTASTIC! They do everything that the Juicedlink Little Darling was supposed to do except these are available now while the Little Darling has been on hold for quite a while.
Michael - this sounds like a good option. I'm assuming a G2/G3 Sennheiser mic is compatible with this?
__________________________________
- Art Varga www.vargaproductions.com
Art Varga is offline   Reply With Quote
Old September 4th, 2015, 08:50 AM   #33
If you purchase the Tascam DR-10CS then that will be compatible with either the G2 or G3. There's another version called the DR-10CL which is made for Lectrosonics and I think it has a different connector. In the DR-10CS menu you can select "Sennheiser" so that it knows what type of transmitter you're connected to for the passthrough.
Old September 4th, 2015, 08:52 AM   #34
I'm sold - will buy a couple for next season :)
P
Old September 4th, 2015, 09:02 AM   #35
Originally Posted by Steven Davis View Post
Hey Michael, did you mean Tascam DR-10C . Are they available in the US somehow? Product: DR-10C Series | TASCAM
I see there is a DR-10C and DR-10CS but neither seem to be sold in the US. Anyone know where to purchase?
Old September 4th, 2015, 09:25 AM   #36
I bought two from this site: Tascam DR 10CS Micro Linear PCM Recorder For Sennheiser Lavalier Microphones at Juno Records
Old September 4th, 2015, 09:51 AM   #37
Hey Chris,
I typically don't clip it on the grooms belt, I go for the breast pockets if I can. Typically the groom has stuff in there that he has to empty so I don't get too much push back on it. My Sennheiser g3 doesn't look to bad in there so I'm wondering if I could rig this, one gizmo in one pocket and wired to another back to the other pocket.
Old September 4th, 2015, 09:58 AM   #38
Thanks Mike!- just placed an order
Old September 9th, 2015, 12:23 PM   #39
My Tascam DR-10 arrived today - I haven't tried it out yet but wow I love the size of this unit - smaller than my G2 transmitter. Thanks for the tip on this MIke.
Art
Old September 9th, 2015, 01:20 PM   #40
That's good to hear that you got your DR-10! They are very small which I think is really helpful when placing it on a groom or officiant. I've also found that when hooked up to my ME-2 it sounds much better than my G3 system does, and I don't have to worry about interference.
Old September 14th, 2015, 01:42 AM   #41
Originally Posted by Steve Bleasdale View Post
Peter i use three olympus me-15, one aspen, one azden 503, the aspen azden are supposed to be better, but there is no difference, steve
Steve did you find a UK supplier for your Aspen mics? I'd like to avoid the import duty and extortionate post office charge if possible
They have them as 'unavailable' on Amazon
Cheers
Old September 14th, 2015, 03:08 AM   #42
I did not Pete i had to import them from USA, trying to find a link for you.
Old September 14th, 2015, 03:12 AM   #43
Azden EX-503 Lapel Microphone: Amazon.co.uk: Camera & Photo
This was the Azden i got.
Old September 14th, 2015, 03:23 AM   #44
Hi Steve
Just for interest I have two Azden setups and the 503 lav's gave me a load of uphill over the years ...maybe the cable and/or the jack plug goes faulty but they were not nearly as good I found as other lavs especially when it comes to durability !! All 3 of mine tended to go bad after a couple of months and being sealed the capsule is non repairable but I felt the main issue was the jack plug as it tended to be very noisy when you wiggled it around.
Pete? you can also get 503's on eBay if you want them ...Azden mics are made in Japan and you can get the genuine mic pre-packed form Hong Kong for $19.95 !!!
Old September 14th, 2015, 03:24 AM   #45
Hmm thanks Chris - I might avoid them and go for the Asden - I'll just suck up the import charge and tax
Peter Rush is offline   Reply
