Vegas Video discussions from 2004 (Q1Q2) - Page 110 at DVinfo.net
Old May 14th, 2004, 09:10 PM   #1636
Add a velocity envelope, and a node at the point you want the freeze to happen.
Add another node (point) to the right and move it directly undeneath the other one. Right click on the bottom node and Set To.. 0%.
Now you can dag out the event however long you want it ,and it will stay on that frame.
Gary
Gary Kleiner is offline
Old May 14th, 2004, 09:13 PM   #1637
While Vegas can now import Acid loops and their metadata.
Vegas is nowhere near what Acid does, and visa versa. Two very different programs.
Gary
Old May 14th, 2004, 11:29 PM   #1638
Man, I should have tried that! Thanks Gary, that worked like a charm.
Tim Le is offline
Old May 15th, 2004, 03:26 AM   #1639
in which ways is ACID more comprehensive than what Vegas offers, in terms of loop-based compositions?
Allen Nash is offline
Old May 15th, 2004, 05:48 AM   #1640
pitch, time, midi set, tempo/beat matching etc.. are all superior in acid
why would they jeopardise a market by offering it all in teh one package?
This way they get more moola
Peter Jefferson is offline
Old May 15th, 2004, 07:16 AM   #1641
RED Code Chef
It might also just be unused media. There is an "Remove all
unused media from project" button in the media pool for this.
I had that too last year and was puzzled by it until I figured out
it was a test clip I did some things with and put up on the
timeline to see if it fitted in with the rest. It didn't so I deleted
the clip from the timeline and from my harddisk.
Next time Vegas asked me for the missing piece. It was still in
my media pool and the cleanup function got rid it of it (could also
have doen it manually ofcourse).
I usually try several different takes of scenes (which are different
AVI files in my setup) and also do a clean media pool every once
in a while to get rid of those references I did not end up using.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old May 15th, 2004, 07:24 AM   #1642
Yeah, that's exactly what I did to fix it. Ugh...media pool- who actually uses that sloppy thing. lol
Glen Elliott is offline
Old May 15th, 2004, 11:33 AM   #1643
Using opacity envelopes for non-destructive cuts
Coming from Photoshop, I like working with adjustment layers. They allow me to modify the image without irrevocably altering the image. I was thinking.... couldn't I use opacity envelopes to cut between scenes? Say I have a main video track, and a supplementary video track. I add an opacity envelope to the latter, and use it to cut between the two tracks. The problem is that opacity envelopes are not conducive to cutting; all changes are smooth. I do not want dissolves; just cuts. Is this possible, and if so, do you think it is a good idea?
Emre Safak is offline
Old May 15th, 2004, 11:45 AM   #1644
Vegas is non-destructive in nature so you don't have to do that.
If you split a clip with "s" and delete one portion, just expand the remaining portion and you'll get your clip back.
Glenn Chan is offline
Old May 15th, 2004, 12:34 PM   #1645
That is true.
Meanwhile I solved the problem: Mute Envelopes are exactly what I wanted. What a great program eh?
Old May 15th, 2004, 08:10 PM   #1646
vegas rebates?
Hi folks;
Anybody get anywhere with the rebate Sony was offering for folks who bought Vegas 4 during the month of April?
I saw it listed on another forum that there is a $50 rebate but when I tried to register I got an error screen.
When I called Sony they said they were aware of not being able to register for the rebate on line and that I would get a phone call saying when they had fixed the problem.
Of course, no phone call as of yet.
Anybody had any luck getting further along in the rebate process?
Aaron J.H. Walker is offline
Old May 15th, 2004, 08:36 PM   #1647
Rendering video with 16:9 and 4:3
Hi all,
Ok so i got two kinds of footage for a video i am editing.
One shot in 16:9
One shot in 4:3
When i rendered it i specifically chose to put it in 4:3 but the end result is that all the shots in 16:9 are widescreened and the 4:3 are full screen.
Is there any way to harmonize the two so they either both go wide or full screen.
Thx a bunch
Phil
Philippe Gosselin is offline
Old May 15th, 2004, 09:18 PM   #1648
Images: 32
One method would be to use the pan/crop tool on the 16:9 footage. Zoom-in/pan/scan so it fills the screen.
Or you could letterbox the 4:3 video using either the Pan/Crop tool or by using a mask.
Michael Wisniewski is offline
Old May 15th, 2004, 09:32 PM   #1649
Sponsor: JET DV
I recommend you call support again - especially if it still doesn't work today. Have you tried it again?
Edward Troxel is offline
Old May 16th, 2004, 12:54 AM   #1650
Though you can cut between scenes by using opacity envelopes, you should be aware that render times may increase dramatically by using this approach as Vegas will be forced to render every frame.
-Dan
Dan Crandall is offline
